Misfire ONLY at idle problem - JeepForum.com
post #1 of 14 Old 05-20-2012, 02:41 PM Thread Starter
chero123
I have a 2004 Jeep GC 4.0 and it has a few problems: one is that the oil gauge goes to zero when engine is warm and at idle. I already replaced the oil pressure sensor (dealer) and still doing it. I will check the pressure with a mechanical gauge, I am suspecting that the pressure is indeed low... But the more puzzling problem: I get a misfire ONLY AT IDLE on cyl 5. Swapped injector from another cylinder, replaced the coil, plugs, problem stays on cyl 5 all the time. Only at idle, if I hit the gas it drives perfect. Injector works when the misfire happens (I can hear it clicking with stethoscope). Tried to find a vacuum leak, found nothing. This is not the typical Jeep heat soak problem, it does it right after I start the cold engine, as soon as the RPMs drop to 700. Basically, not much heat under the hood at all...
This is a new vehicle to me, don't know what happened to it before. Any ideas?
chero123 is offline
post #2 of 14 Old 05-20-2012, 05:58 PM
MrElPoderozo
1979 CJ7
I am not familiar with that engine but can you SWAP the spark plug WIRE for another one and see if the problem goes away or if you swap the wires from another cylinder for the one in #5(MARK THE WIRE ON CYLINDER #5) and see if it moves to where the bad wire is(THE MISS FIRE). Sounds like it could be a bad spark plug wire or a bad connection on the Distributor also check the Rotor connection on the cap for cylinder #5. Sometimes when we make are own wires and we put the connection through the boot it gets disconnected from the crimping. you say that it runs good when you drive it and I think its because when you are driving it it creates more spark and is enough to run good. I don't know how many miles on the engine but the low oil pressure could be a bad oil pump,wrong viscosity, or the bearings might be worn out. I am no expert but I try to help,I hope that this will help you,good luck to you.
MrElPoderozo is offline
post #3 of 14 Old 05-20-2012, 08:36 PM Thread Starter
chero123
No wires on this engine, has a coil pack for all 6 cylinders.
chero123 is offline
post #4 of 14 Old 05-20-2012, 08:59 PM
hillbilly07
I have a 2007 wrangler x and I am having some major problems with It ...... I fueled up and as soon as I went to start it it would only turn over. I pushed it in to a parking spot and tried again but it would do anything not turn over or anything the Lights and instrument panel lights would turn on and that was about it. I tried jumping the starter And all it would do is turn over. I need some help here please
hillbilly07 is offline
post #5 of 14 Old 05-20-2012, 10:21 PM
MrElPoderozo
1979 CJ7
Sorry! Did you checked the timing? and the cam sensor? or crank sensor? I would check those things next ORRRRR!!! sense you can drive it take it to AUTO ZONE or Advance Auto parts and have them put the scanner for ((FREE)) LOL, before taking it to a mechanic,good luck to you.
post #6 of 14 Old 05-20-2012, 10:44 PM
MrElPoderozo
1979 CJ7
Sound like fuel pump problem to me,if you turn the switch to the ON position and you cant hear the fuel pump RUNNING then that could be your problem. Usually fuel pumps don't give warnings when they go out on you except they get louder but not to many people notice that. I would also look into the fuse box for broken fuses (CHECK YOUR MANUAL). The bad part about this is that it could be soooooo many things wrong that its hard to know without actually looking at the car, but if I was in your shoes I would check the fuel pump,fuses and see what the Manual says about overfilling the tank sometime they put some sorta check valve and some bull %$#@ that makes thing complicated and take it from there,I wish you luck with this project.
post #7 of 14 Old 05-21-2012, 07:45 AM Thread Starter
chero123
I checked to code on my Jeep, it's misfire on cyl 5.
chero123 is offline
post #8 of 14 Old 05-21-2012, 04:56 PM
obfdcherokee
Your misfire sounds like a valve problem. At idle the valve isn't closing all the way. This cause compression loss and blows the fuel right out the tail pipe. It quits off idle because it's moving faster and not as noticeable. You probably have carbon build up or a weak valve spring. do a compression test and compare 5 to the others. As for the oil pressure probably oil pump or main bearing wear. Hope this helps
obfdcherokee is offline
post #9 of 14 Old 05-21-2012, 04:58 PM
bprks55
Possible Intake Gasket, At higher RPMs. It won't show up
bprks55 is offline
post #10 of 14 Old 05-21-2012, 05:25 PM
obfdcherokee
Yeah but massive vac leak would occur
post #11 of 14 Old 05-22-2012, 08:12 AM Thread Starter
chero123
I suspected a vacuum leak/intake gasket too, but I could not get the idle to change at all when spraying carb cleaner around #5. Usually a big vaccum leak that will result in a misfire would be very evident, most of the time I can even hear it. Unless it leaks somewhere inside the manifold, like exhaust leaking inside the intake?!
The compression sounds the most probable based on all the tests so far, but when I crank the engine without starting, it sounds like it has good compression on all 6 cylinders. I will try to get a compression reading today, and put a number in place of "sounds good". But I suspect the compression is going to come back good.
chero123 is offline
post #12 of 14 Old 05-22-2012, 08:23 AM
hillbilly07
Well I got it in the shop in just wait waitin on the prognosis.....do you think a run relay fuse could cause all of this?
post #13 of 14 Old 05-25-2012, 11:12 PM
MrElPoderozo
1979 CJ7
yes ,I think a broken fuse can cause that and more. cars now days have one fuse for more then one thing at the time, like wipers would not work if you remove the fuse from the hazardous lights etc... I hope that you got the problem fixed at the shop and that you are ok now,sorry I was not much of a help to you,good luck to you ok.
post #14 of 14 Old 05-30-2012, 07:53 AM Thread Starter
chero123
I finally got around to measure the compression, all cylinders show perfect compression. I am still thinking a vacuum leak, or most likely a crack in the head between exhaust on #4 or #5 and intake on #5. I will post my findings if I ever get to fix it.
chero123 is offline
Idle / acceleration problem emsmasters48 General Jeep & Off-Road Equipment 0 04-05-2012 02:10 PM
misfire problem dboy Engines & Drivetrain 1 12-09-2011 11:16 AM
Idle problem on my CJ7 ablack9134 Engines & Drivetrain 1 06-30-2009 03:12 PM
Idle Problem Datspoon Engines & Drivetrain 0 09-28-2008 08:35 PM
Idle Problem Trainer Engines & Drivetrain 5 09-20-2003 12:14 AM
