Misfire on Cylinder 1, low compression on cyl 1 - JeepForum.com
post #1 of 8 Old 07-04-2012, 03:27 PM Thread Starter
Xtremegameroom
Hi guys, I have been getting misfire on Cyl 1 randomly for the last 3 months or so. When I first got the misfire, I replaced all the plugs, and the ignition rail. It seemed to be fine for a couple weeks then it started up again. Then I replaced the injector on Cyl 1 and it ran good for a couple more weeks. then it started up again. So today I ran a compression test and heres what I got:
143 PSI Cyl 6
152 PSI Cyl 5
151 PSI Cyl 4
151 PSI Cyl 3
152 PSI Cyl 2
82-89 PSI Cyl 1
I tested cyl 1 three times. the first time it read 89, the 2nd time it read 130, the 3rd time it read 82 PSI.
What should I look for? Cracked head possibly? Blown head gasket?
Thanks
Xtremegameroom is offline
post #2 of 8 Old 07-04-2012, 06:49 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
With the intake boot removed, use a 8 ounce cup of water and dribble it slowly into the throttle body while using the linkage to keep it from stalling. Repeat with a second or third cup. The water will cause any carbon under a valve to break off and allow the valve to seat again.
cruiser54 is offline
post #3 of 8 Old 07-10-2012, 09:22 PM
ruggles
Has anyone else tried this? I have a dead cylinder on my 2.5L maybe I'll give that a shot
ruggles is offline
post #4 of 8 Old 07-10-2012, 09:44 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
This has been done for years. Go for it.
post #5 of 8 Old 09-07-2012, 03:17 PM
Mboelts
I have got to try this before I start tearing my engine apart...
-"I feel sorry for people who don't drink. When they wake up in the morning, that's as good as they're going to feel all day." - Frank Sinatra
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
KCCO!
Mboelts is offline
post #6 of 8 Old 09-07-2012, 04:28 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Can't hurt. Just be prudent as you're pouring it in.
post #7 of 8 Old 09-07-2012, 07:00 PM
Mboelts
Think ill just use a dollar store mister bottle
KCCO!
Mboelts is offline
post #8 of 8 Old 09-07-2012, 07:02 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Why not?
low compression and misfire on Cyl 5 CalPalYJ Engines & Drivetrain 0 07-03-2012 02:59 PM
Cylinder 6, No compression? XJGoinUp Engines & Drivetrain 15 12-06-2011 05:12 PM
Lost compression in one cylinder blowback Engines & Drivetrain 19 09-13-2011 06:59 PM
Cylinder 6 Misfire cash5432 Engines & Drivetrain 3 04-07-2011 03:24 PM
cylinder compression #1 technical question?????? jaybyrd Engines & Drivetrain 1 08-20-2002 07:35 AM
