Mercedes OM617 users... - JeepForum.com
post #1 of 14 Old 04-06-2011, 02:21 AM Thread Starter
Hussler
1992 XJ Cherokee
Just looking for experience from people that used this engine for their conversion. Generally just how happy you are with the power, problems you ran into while converting and most important
MILES PER GALLON!
Originally Posted by chris87xj View Post
Sometimes a restoration project is a labor of love, at which point cost, time, and labor involved become irrelevant.
Originally Posted by BorderC View Post
I see you also twizzled your scart lead. Well done! :thumbsup:
92 XJ with ARB's, 5" lift, too much armor, 33's and some other garbage
Hussler is offline
post #2 of 14 Old 04-06-2011, 03:04 PM Thread Starter
Hussler
1992 XJ Cherokee
Nobody? bummer
Hussler is offline
post #3 of 14 Old 04-06-2011, 05:38 PM
superduty59
I'm in the process of doing it right now. I should be done in about 1.5 months. Mine is a OM617 into a 88 YJ with an AX-15.
superduty59 is offline
post #4 of 14 Old 04-06-2011, 08:40 PM Thread Starter
Hussler
1992 XJ Cherokee
I hope you have a build thread going!!!
Hussler is offline
post #5 of 14 Old 04-07-2011, 07:08 PM
superduty59
I plan on doing one but here is a XJ link http://www.dieselbombers.com/diesel-...0r4-np231.html
post #6 of 14 Old 04-08-2011, 08:38 AM
KLT88YJ
Do a Google search...there was a member on here who did this swap with success. He started selling the adapter plates. I'd give you the name of the site but I forgot it...if o come across it ill post it up. Actually YouTube "Wrangler om617" should bring up a few videos...the website is in one of them (believe its a brown wrangler w/ Mercedes emblem on the grill)
KLT88YJ is offline
post #7 of 14 Old 04-08-2011, 03:23 PM
superduty59
Here is the site. http://mercedesdiesel4x4.com/default.aspx
jeep-dsl is his screen name.
post #8 of 14 Old 04-08-2011, 05:29 PM Thread Starter
Hussler
1992 XJ Cherokee
Sweet site, all the info I need!
Thanks!
Hussler is offline
post #9 of 14 Old 05-09-2011, 01:08 PM
srmitchell
Bump. Anyone else do this?
If love to drop an om617 into my 2001. Legally, it might be a mess.
I watched a show last night about algae oil biodiesel and waste veg oil. So sick, less emissions and pretty cheap.
I work on Mopars
srmitchell is offline
post #10 of 14 Old 05-10-2011, 10:56 AM
duffer
1955 CJ3B
Perhaps you should check out what repacement parts cost for those engines before you swap. I put a couple hundred k miles on two different cars with those and both got mid 30's for mileage-not bad for full sized cars. After you get by the turbo lag, there is plenty of torque-but next to nothing before spooled up.
Down side: they generally do not go any farther than modern injected gas engines before needing a rebuild and you can build a really wild completely aftermarket Chevy small block for about 1/2 of what a rebuild costs on a 617. I still have one of those Benz's (82 300CD), along with a 83 380SL and both are going away ASAP-parts are just too ridiculous, even if you do all the work.
duffer is offline
post #11 of 14 Old 05-10-2011, 04:14 PM
srmitchell
I would NEVER swap a gas motor in. Way too inefficient. But yeah, you're right, they are probably fading away.
I work on Mopars
post #12 of 14 Old 05-10-2011, 06:45 PM
superduty59
Never a gasser only diesel. A gassser engine can't use cooking oil, used motor oil, used tranny fluid, ect as fuel. Only a diesel can. I would have to disagree about the miles before a rebuild. I have seen 4 OM617's with 500,000+ miles without a rebuild. The worlds record for a street driven vehicle has a OM617 in it and has almost 2 million miles and counting without a rebuild. I don't know of any gassers doing anything like that.
I haven't priced a lot of parts for my OM617 yet just common wear items like water pump, timing components, injectors, glow plugs, ect and were very cheap. A water pump was only like $36.
post #13 of 14 Old 05-10-2011, 09:52 PM
srmitchell
My buddy has a 300d, and it runs like a top. It needs new tires though, so it's back at his home, 300 miles from school. He is driving a Honda instead, and it just doesn't have the character and quality like the Benz!
I'd agree, the om617 is akin to the jeep 4.0. Most just need minor maintenance.
I work on Mopars
post #14 of 14 Old 08-15-2011, 02:22 PM
OM617orBUST
OM617 into 89' YJ
Hi guys, im getting everything together to pull off this swap. Found a low miles 82' 300TD that has little blow by and no leaks of anykind. YJ's 4.2L is getting tired, and it has a AX15. Seems like a pair of motor mounts and a bell housing adapter, fuel line swap, and some other trivial block grinding, oil pan hacking will be needed. All in all I was a fan of a 4BT, until I realized I could pull this swap without a stack popping out of my hood; and a more importantly, pull it off for the price i had set aside for a 4BT, while keeping my stock drivetrain. I think the 617 is a wonderful alternative to the 4BT, if sub par performance is acceptable to you, assuming you can get a donor car for next to nothing. I hope to be ordering a bell housing adapter from Koch Enterprises (who has already been incredibly helpful and informative over the phone about what to look for when buying a 300D) along with motor mounts within the week. If anybody has tips suggestions or what-not let me know! Ive been reading JEEPFourm.com for some time now, but only today became a member. Lots of great info here, and everyone seems friendly and very helpful to each other. First thing on my list though is to upgrade from the free membership ASAP, im realizing all too quick 200x200 pixels isnt gonna cut it.
OM617orBUST is offline
Mercedes Keith General Discussion 15 05-04-2010 08:15 AM
2 mercedes for $250 Indy General Discussion 11 06-15-2007 12:57 PM
Anyone into old mercedes? KWAG General Discussion 4 06-08-2007 03:03 PM
Offroading with a Mercedes... Steelman General Discussion 17 11-15-2005 03:41 AM
