Mechanic Says My Engine Is Dying :( - JeepForum.com
post #1 of 3 Old 08-30-2016, 09:04 PM Thread Starter
MilkmanDan
My 1996 Jeep Country started to sputter a few days ago so I called my mechanic. When he took a look, and did a pressure test, he said three misfires happened and two of them are running at about 70-90 psi. I scheduled for him to do a tune-up (plugs, wires, distributor, rotor) to at least help it. He told me that it will still eventually end up the same. Any suggestions? Am I screwed?
MilkmanDan is offline
post #2 of 3 Old 08-31-2016, 12:00 PM
Fourtrail
1974 CJ6
Until a leakdown test is performed to find out where the compression is escaping to, there is no way to tell. Might be as simple as a couple of burnt valves and a head rebuild will fix it. Could be as indepth as the piston rings/cylinder wall are excessively worn and you will need a complete engine rebuild. Until more testing is done we can't give anything more than a speculative guess on what the problem is and what it will cost to fix. If the body/trans/interior are all in good shape, then a reman motor or a rebuild is cheaper than 6 mo payment on a new car.
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is offline
post #3 of 3 Old 08-31-2016, 01:50 PM
222Doc
222Doc's Avatar
Yep and top that with expensive licence fees, INS, and new stuff is far from trouble free, dealers at times are not much better on these new ones than a shade tree mechanic as well.
222Doc is online now
engine , help please , misfires , sputtering , tune up
