maybe water pump - JeepForum.com
post #1 of 14 Old 11-30-2013, 07:23 PM Thread Starter
schatzzy
1995 FSJ Cherokee
maybe water pump
was wondering has any one had little heat when at idle to good heat on throttle rad is full i don't see any movement in rad when idleing but rev it it is moves just a little but not like i have seen before and just put new temp switch in and reads really high when running but rad is cold as can be any idea's
stuff breaks all the time just got to fix it and move on if you can't wrench it weld it
schatzzy is offline
post #2 of 14 Old 11-30-2013, 07:25 PM Thread Starter
schatzzy
1995 FSJ Cherokee
1995 grand cherokee 4.0l and idles high like my old 89 f150 used to do if she got hot
schatzzy is offline
post #3 of 14 Old 11-30-2013, 08:22 PM
BIGBADWOLF
That is what it sounds like. Check water pump impeller
BIGBADWOLF is offline
post #4 of 14 Old 12-01-2013, 10:35 AM Thread Starter
schatzzy
1995 FSJ Cherokee
trying thermostat i just had a dumb thought and hoping it is it it maybe stuck closed
schatzzy is offline
post #5 of 14 Old 12-01-2013, 01:08 PM
copmedic309
1995 XJ Cherokee
Sounds like the thermostat. Flush out your heater core as well
Ry.
Rather be tried by 12, than carried by 6.
copmedic309 is offline
post #6 of 14 Old 12-01-2013, 02:21 PM
BIGBADWOLF
heater should still work with a stuck thermostat
post #7 of 14 Old 12-02-2013, 07:43 PM Thread Starter
schatzzy
1995 FSJ Cherokee
well still didn't fix it looking like water pump aint pushing coolant very well just didn't want to do it but have too
schatzzy is offline
post #8 of 14 Old 12-02-2013, 10:41 PM
BIGBADWOLF
Yup I would almost bet the impeller is broken or worn. Heater is not controlled by thermostat...water circulates through heater whether thermostat is open or closed. So if heater ain't putting out warm air and hoses are cold that is usually a bad water pump.
post #9 of 14 Old 12-03-2013, 12:12 AM Thread Starter
schatzzy
1995 FSJ Cherokee
i got more heat when on throttle than idle and when i pulled thermostat i notice that the thermostat has nothing to do with heat i used to different vehicles where the thermostat or does control that i using some of my knowledge but as i can see jeep is not normal lol its crazy stuff hoping heat pipe will unscrew when i get the new water pump
schatzzy is offline
post #10 of 14 Old 12-03-2013, 08:11 AM
BIGBADWOLF
Sounds like a weak pump. Heater pipe usually comes off easy, a vice helps. Be sure to use thread sealant B/C the pipe has to be in the correct position so you may not get it all that tight. I like to use Permatex indian shellac. but that is just me. Also use sealant on the bolt that goes all the way through the block and into the water jacket.
post #11 of 14 Old 12-03-2013, 10:45 PM Thread Starter
schatzzy
1995 FSJ Cherokee
need a good cleaner i can add to antifreeze cos its cold here and run it for a bit cos i put new pump on it still running warm not over heating but warm enough i just wondering if anti freeze is not getting to the new temp switch i did get it a little cooler but not much so not sure whats going on
schatzzy is offline
post #12 of 14 Old 12-04-2013, 02:40 PM Thread Starter
schatzzy
1995 FSJ Cherokee
here where it running at
schatzzy is offline
post #13 of 14 Old 12-05-2013, 09:40 PM Thread Starter
schatzzy
1995 FSJ Cherokee
any body with any idea's for this please
schatzzy is offline
post #14 of 14 Old 09-05-2016, 12:10 PM Thread Starter
schatzzy
1995 FSJ Cherokee
this still the same
schatzzy is offline
