Manual Transmission/clutch fluid leak...? - JeepForum.com
post #1 of 3 Old 09-21-2012, 03:56 PM Thread Starter
jeepluv99
unfortunately my first post is a problem post...
i have a slow leak (a quarter to a baseball size puddle per day, is that slow?) from a seal or something on my 99 wrangler manual transmission. its wet toward the rear and there's a red seal between two different parts of the tranny that looks shot. i think the fluid is a red color, and my skid plate is always wet, with drips forming. I don't know that its a seal problem, could there be something wrong with the tranny internally? Is it cheaper/ easier to just fill fluid as it gets low at this rate...i mean, does this sound like a slow leak or fast?
Jeep has 84000 on it.
No real issues shifting or clutching.
Is it bad to leave it in gear when parked?
Is it bad to pull it into neutral without clutching?
thank you so much.
otherwise the jeep has been tons of fun.
jeepluv99 is offline
post #2 of 3 Old 09-25-2012, 01:37 PM
seattle_yj
What I suggest is to clean up the area with degreaser the best you can and really try to isolate the leak. Snap a picture if you can, that way folks here can zero in on the issue.
In regards to this:
Leaving it in gear when parked is probably a good thing, especially if you live on a hill, that way your rig doesn't go rollin down the street. That should be fine, though sometimes on a large incline/decline you will get a little binding when parked. What I do is stop, press ebrake, THEN put into gear.
Regarding the neutral, I'm not super advanced as to the internals of this but I would use the clutch. When going through the gears or from gear to neutral.
seattle_yj is offline
post #3 of 3 Old 09-25-2012, 01:39 PM
seattle_yj
Oh and there is probably only a few quarts in your transmission, so if it is leaking a baseball sized puddle every time you park, you might be loosing an 1/10 quart a day or so, these trans are pretty tough but of course its bad to run with less than spec fluid levels. Get it fixed up man you'll feel better
Manual Transmission fluid? sjeep Engines & Drivetrain 3 11-07-2011 01:28 PM
How to add fluid to manual tranny.. 97' Wrangler, 4.0.. help? EEN5141 Engines & Drivetrain 2 10-07-2011 11:46 PM
94 5speed manual, how much new fluid needed to change out old fluid csamanie Engines & Drivetrain 0 06-22-2011 03:53 PM
Mopar manual transmission fluid VikesTJman Engines & Drivetrain 1 04-01-2009 04:03 PM
manual bellcrank clutch vs Hydraulick clutch jphillips13 Engines & Drivetrain 1 07-09-2008 10:25 PM
