Lube Lockers - JeepForum.com
post #1 of 6 Old 11-06-2013, 04:17 PM Thread Starter
Eckoh
Lube Lockers
What do people think of these... my front diff is leaking again and i need to do something other then RTV i think i keep failing at it the rear sealed fine but i cannot get the front to seal for crap.
Eckoh is offline
post #2 of 6 Old 11-06-2013, 04:31 PM
biffgnar
biffgnar's Avatar
Have worked well for me
biffgnar is offline
post #3 of 6 Old 11-06-2013, 05:48 PM
BlueRubiconrich
I have yet to install mine, should work great.
Rubicon Rich ,05 TJ Rubicon: PatriotJeepers.com
86 CJ7 258,T18,Scout Dana300,twin sticks,Dana44's,4W Disc, locked,35's,YORK OBA,Warn 8274,fullcage.
51 M100 1/4 ton Jeep trailer
BlueRubiconrich is offline
post #4 of 6 Old 11-07-2013, 09:18 PM
GilaMtnJeep
GilaMtnJeep's Avatar
Lube Locker gaskets are awesome and they're reusable, too!
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
GilaMtnJeep is offline
post #5 of 6 Old 11-11-2013, 06:37 AM
timmayham
I noticed this thread is a few days old, but I would like to weigh in. I have never used a lube locker or even sealed more than a couple of diffs. I would recommend though to ensure your mating surfaces are clean and not warped/ damaged. OEMs are able to get a seal that lasts for years and tens of thousands of miles with cork. I am not poo-pooing on the lube locker, I am looking to redo my ring and pinions in the next month or so and a reusable gasket sounds like a real good idea. Good luck sealing up your stuff, just wanted to throw that thought that there could be a deeper issue than just the gasket.
Proving daily that I have gears for brains!
timmayham is offline
post #6 of 6 Old 11-11-2013, 07:20 AM
Tdog02
RTV on diff covers is simple and cheap. It's also a PITA when cleaning it off during changes and makes the job a lot longer and messier.
Lube lockers are a nice addition and have been reused (on my rig) three times without issue. I would only use RTV as a field expedient fix if I couldn't reuse the gasket.
it is what it is except when its something else
Tdog02 is offline
