Low Idle, Spudder Out, Stall Out!!! HELP - JeepForum.com
post #1 of 3 Old 10-28-2011, 06:21 AM Thread Starter
mreilly4
I have a 2000 Jeep Warngler 2.5L 4 Cyl Automatic Transmission. My Jeep has about 170k miles on it and lately has been dipping low with the RPMs when I switch from D to R or vice versa. Also, when I come to a semi-abrupt stop the RPMs will dip real low and the care will shake a bit.
Any ideas on what this might be?
Any thoughts on how I can fix it? Cost?
Thank you very much.
Mike
mreilly4 is offline
post #2 of 3 Old 10-28-2011, 06:32 AM
wwch99tj
Any codes? Could be a number of things throttle position sensor, o2 sensors or try cleaning the throttle body
http://www.jeepforum.com/forum/f9/cl...mmies-1114849/
Sent from my DROID 2 GLOBAL using Jeep Forum
wwch99tj is offline
post #3 of 3 Old 10-28-2011, 08:17 AM Thread Starter
mreilly4
I had the codes read a few months ago, when a similar issue happened, and I had a TPS issue. I bought a new TPS, however, before I installed it my check engine light went off and the issue stopped. I guess I should go ahead and have it installed and have associated parts cleaned out.
Thanks for the help.
Mike
mreilly4 is offline
idles rough , low idle , low rpm , sputtering , stalling at stop
wants to stall when making a turn sometimes. Danny0717 Engines & Drivetrain 0 10-24-2011 11:41 AM
'98 2.5L wants to stall in Idle dubv72 Engines & Drivetrain 3 05-31-2011 06:20 AM
89 XJ Wants to stall at stops My1989Jeep Engines & Drivetrain 0 04-06-2011 09:16 PM
Sputtering or wanting to stall? JEEPBURGH Engines & Drivetrain 1 10-28-2009 07:48 PM
uphill stall? mike mcgovern Engines & Drivetrain 2 02-11-2002 11:43 PM
