loud knocking oming from valve cover - JeepForum.com
post #1 of 4 Old 11-24-2012, 12:07 PM Thread Starter
Tonye35
1997 XJ Cherokee
I have a 1997 grand Cherokee limited 5.2.
there is a loud knocking coming from the vale covers on both sides. Could this be caused by the oil pump
Tonye35 is offline
post #2 of 4 Old 11-25-2012, 06:41 PM
offroadfreak69
Sounds like your camshaft
offroadfreak69 is offline
post #3 of 4 Old 12-05-2012, 06:23 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
What is your oil pressure at hot idle?
Noises in the valve cover (s) can be, but are not restricted to; collapsed lifter(s), bent push rod(s), rocker(s) that are loose/worn/broken. broken valve spring(s) or bent push rod(s). Then there is the possibility of a bad cam lobe(s).
Merry freakin Xmas......
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #4 of 4 Old 12-05-2012, 10:01 PM
offroadfreak69
You mean christmas not xmas
