Lots of Check Engine Codes! PLEASE HELP! - JeepForum.com
post #1 of 6 Old 05-08-2012, 04:26 AM Thread Starter
Brooksie1of1
2005 KJ Liberty
I have a 2005 Jeep Liberty with 126,680 miles on it, the 3.7L V6 and Automatic transmission. The check engine light came on, so I did the "key dance" and it came up with a mess of codes! Here's what it gave me; P0203, P0201, P0204, P0205, and P0174.
Any ideas of what could be causing this? Any help would be appreciated! =]. Thank you!
Brooksie1of1 is offline
post #2 of 6 Old 05-08-2012, 06:47 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Google the codes.
cruiser54 is offline
post #3 of 6 Old 05-08-2012, 06:55 AM Thread Starter
Brooksie1of1
2005 KJ Liberty
i already did, i know what they are, i just want to know what might be causing all 5 to appear at the same time.
post #4 of 6 Old 05-08-2012, 06:57 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Well, what are the code descriptions?
post #5 of 6 Old 05-08-2012, 07:06 AM Thread Starter
Brooksie1of1
2005 KJ Liberty
P0203 Injector 3 Control Circuit
P0201 Injector 1 Control Circuit
P0204 Injector 4 Control Circuit
P0205 Injector 5 Control Circuit
P0174 Fuel Trim System Lean Bank 2
Any ideas? bad fuel injectors maybe?
post #6 of 6 Old 05-20-2012, 12:04 PM
Lovers7043
I had P0203 code coming up on mine and AutoZone told me that I needed to replace Coil #3 .So I did and I went ahead and got plugs to change them out why I was under the hood and I put new gaskets around each old coil cause coils aren't cheap. Now my truck better then it has ever ran even better then when I first bought.It still had regular
Plugs on it Don't know if that help but I hope so.
Lovers7043 is offline
Check Engine, Crank AND Cam position sensor codes Ruffnek Engines & Drivetrain 15 06-02-2012 11:23 PM
Engine Problems: overheating, check engine light jp1020 Engines & Drivetrain 0 04-29-2012 09:50 PM
check engine light stops engine trouble. Damnit94 Engines & Drivetrain 4 04-10-2012 08:13 PM
Jeep Cherokee Check Engine Light, but no error codes found. engineernick Engines & Drivetrain 0 11-24-2011 04:40 PM
help with engine codes! countryboy5544 Engines & Drivetrain 5 07-08-2011 07:44 PM
