Looking for help in engine swap choices, Chevy, Jeep, or any others - JeepForum.com
post #1 of 5 Old 04-09-2009, 07:12 PM Thread Starter
rosenb1995yj
I have a 95 yj and i would really like to get rid of the 2.5 and AX-5 combo. I have done research but i cannot get a strait answer from anybody. I have narrowed it down to three choices.
4.3 chevy v-6 and NV 3550 to my NV231
5.3 chevy v8 and NV 3550 to my NV231
or
4.7 from the Grand Cherokee or Dakota to the NV3550.
I dont have a ton of money to spend but does anyone know if the 4.7 will accept the AX-15 or NV3550 with no adapter?
Which Tranny is better and is it strong enough?
And Which combo will give me the best option to be a dual purpose jeep?
And finally any other suggestions?
rosenb1995yj is offline
post #2 of 5 Old 04-15-2009, 08:05 AM
FrankZ
1997 XJ Cherokee
http://www.novak-adapt.com/knowledge/xj_swap.htm
FrankZ is offline
post #3 of 5 Old 04-15-2009, 08:32 AM
YeepieJeepie
Actually this is the one for the YJ:
http://www.novak-adapt.com/knowledge/yj_87_95_swap.htm
Also peruse the www.advanceadapters.com site.
I decided to go with a GM engine for my swap. The engines are more common and the swap has been done many times so there's more info and parts available. I thought about the V6, but since it has only a slight HP advantage over the 4.0L for much more work. I decided to go with a V8 Vortec engine. 5.3L Vortecs are very common and Novak says your NV3550 should handle it. You'll need a bell housing adapter.
According to Novak: "GM engine swaps are almost invariably easier, more productive and more affordable than Dodge, Ford and other conversions. These companies make some great engines, but you have to pick your battles when doing a swap and going with a well supported, well documented, easily acquired and broadly familiar powertrain is a key to success and satisfaction."
I'm going with a 6.0L Vortec. I figure if I'm going to do this, I'm going all the way. But I'll have to swap out my transmission too, as well as the rear end.
YeepieJeepie is offline
post #4 of 5 Old 04-15-2009, 08:52 AM
FrankZ
1997 XJ Cherokee
OOPS! I gots too many of dem der pages bookmarked.
Sorry 'bout that.
FrankZ is offline
post #5 of 5 Old 07-02-2009, 11:42 PM
FrankZ
1997 XJ Cherokee
FWIW,
I'm currnetly working on my swap. I picked up a 99 5.3L for $150 and am in the process of rebuilding it...well still working on cleaning up the heads right now.
For those that are planning on swapping an LS motor into their rig:
www.LS1tech.com
FrankZ is offline
2002 Jeep Liberty 3.7L Engine Swap to newer 2004 engine 1SickWS6 Engines & Drivetrain 17 11-29-2016 07:24 PM
Engine for non-jeep swap jbolty Engines & Drivetrain 3 04-23-2009 09:36 AM
Chevy V6 swap Grey4.0L Street Jeep Forum 2 11-20-2007 04:30 AM
Radiator with 4.3 chevy engine swap redrock82 Engines & Drivetrain 2 04-27-2007 12:27 AM
Need new engine for 87...choices? wayward Engines & Drivetrain 3 06-08-2002 05:34 PM
