Lesson - in diffs - JeepForum.com
post #1 of 4 Old 04-07-2012, 11:26 AM Thread Starter
ineedyjeepy
Lesson - in diffs
Think I roasted my front carrier in my WJ. I'm looking for a "how to" guide on building a differential. I'm pretty mechanically inclined, however, I've never set a ring and pinion. Can anyone recommend a website or book or tutorial on how to do so? Thanks in advance!
ineedyjeepy is offline
post #2 of 4 Old 04-07-2012, 12:22 PM
Technohead
http://www.pirate4x4.com/tech/billavista/Gear_Setup/
-Eric
Technohead is offline
post #3 of 4 Old 04-07-2012, 07:46 PM Thread Starter
ineedyjeepy
Oh wow. PERFECT! Thanks Techno!
post #4 of 4 Old 04-07-2012, 08:39 PM
AKGeo
How do you 'roast a carrier'?
did you destroy the ring and pinion? Did you destroy your spider gears? If you need to replace the spiders or any clutch packs in a limited slip, you don't need to do any real setup work, just take the ring and carrier out, save your shims for each side, do whatever you need to the carrier, then put it back the way it came out.
AKGeo is offline
