Leaky transmission...HELP! - JeepForum.com
post #1 of 3 Old 05-30-2012, 05:52 PM Thread Starter
G-Wag
1986 FSJ Wagoneer
Got a 86 wagoneer that started leaking tranni juice in the driveway!
I put some lucas before, could have caused the problem? Also I'm reading that maybe I should use ATF +4 as a substitute for the Mopar ATF plus type 7176 recommended by the Haynes manual. Thanks!
G-Wag is offline
post #2 of 3 Old 05-30-2012, 11:21 PM
jnicewan
Dont blame a fluid additive like lucas on the leak, you need to find where its coming from and hopefully its something easy like a cooler line or pan gasket. More than likely due to age you have a seal or gasket thats worn or hardened/cracked causing the leak. You can use ATF+4, it basically supercedes the older mopar fluids.
jnicewan is offline
post #3 of 3 Old 05-30-2012, 11:32 PM Thread Starter
G-Wag
1986 FSJ Wagoneer
I always used lucas with my Toyotas with no prob, just seemed coincidental. Thanks for your tip, got my weekend planned.
G-Wag is offline
