Leaking Trans fluid - JeepForum.com
post #1 of 7 Old 01-03-2013, 07:32 AM Thread Starter
sb95xj
1995 XJ Cherokee
Leaking Trans fluid
Okay so im leaking trans fluid out of my 95 xj, i do not know where its coming from... im thinking maybe front main seal? idk.. i need ideas on what it could be..
sb95xj is offline
post #2 of 7 Old 01-03-2013, 12:10 PM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
Hmmm, if you cant tell the general area of the leak, when you can see it, how can we tell from the internerd with no foto's?
Clean it all off, keep an eye on it, proceed from there.
Could be tranny cooler line connections, lines themselves, or any one of a number of seals.
Martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
post #3 of 7 Old 01-03-2013, 12:13 PM Thread Starter
sb95xj
1995 XJ Cherokee
thanks ill do that.... i also heard that my trans type has no real main seal? due to something i dont remeber what though
sb95xj is offline
post #4 of 7 Old 01-03-2013, 12:59 PM
leftlanetruckin
XJ on 37's
There will be a seal between the transfer case and the rear of the transmission, has to be.
There is also a seal that the torque converter slides into.
There are other smaller seals (IIRC) around the various parts that bolt onto the tranny.
There are the tranny cooler lines, and their fittings.
The transfer case also takes ATF (IIRC again), so it could be from there too.
See what I mean?
You can spray it all down with brake cleaner and see what gets wet first, then go from there.
Martin
post #5 of 7 Old 01-03-2013, 04:43 PM
seattle_yj
Just to add to the above, my 93 auto tran will take ATF+4 but the transfer case is dexron. Check your service manual or chiltons for the fluid type.
I'm a pro at finding leaks, especially those annoying 1-2 drippers. I clean the whole thing with purple power and the blue shop towels. Then run some white chalk around the areas I suspect. The white chalk will show the red ATF better then it shows on bare metal.
seattle_yj is offline
post #6 of 7 Old 01-03-2013, 07:04 PM
leftlanetruckin
XJ on 37's
Excellent idea
Martin
post #7 of 7 Old 01-04-2013, 09:42 AM Thread Starter
sb95xj
1995 XJ Cherokee
thanks guys.. ill do that today while its up in the air on the lift...doing a three in rought country lift today..and cramming everything closer to my motor and away from wheel wells and choppin the wheel wells to run some 35s on a 3 in lift. while still having some flex.... rowdy
sb95xj is offline
