Leaking Coolant onto Passenger Floor - JeepForum.com
post #1 of 13 Old 09-05-2013, 12:57 PM Thread Starter
LV2DRFT
I've got a little problem... I've been noticing a little coolant leak over the last few months (from "FULL" to "ADD" about every 6 weeks).
My heater and A/C have not been working for years and I don't really need them anyway.
Now I'm noticing little puddles (about 4 teaspoons worth) of engine coolant seeping in from the firewall area and collecting on the passenger floor.
I've heard of people bypassing their heaters because of an issue with the heater core... would this be a situation where doing this would help? Any suggestions? btw I like the cheapest way out for my jeep and don't need a/c or a heater because I've got redneck air conditioning (permanent summer mode jeep) and a jacket for the winter ;-)
Thanks!
LV2DRFT is offline
post #2 of 13 Old 09-05-2013, 04:54 PM
Terry777
1997 XJ Cherokee
Not sure why you couldn`t just join the in & out hose to by pass the heater core before it enters the firewall ?
I don`t know if it would affect the over all pressure of the system but my guess would be it wouldn`t ???
Terry777 is offline
post #3 of 13 Old 09-05-2013, 10:24 PM
jokerchief462
Works fine just bypass the core no ill effects on your cooling system
Sent from underneath my Jeep
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #4 of 13 Old 09-05-2013, 10:27 PM
uberxj92
1992 XJ Cherokee
It doesn't hurt anything. I do it often
http://www.jeepforum.com/forum/f177/92-xj-sadness-2075657/index2.html
uberxj92 is offline
post #5 of 13 Old 09-06-2013, 10:11 AM
Speedymcracer01
I've done the same it just saves coolant, helps keep the floorboard dry
Speedymcracer01 is offline
post #6 of 13 Old 09-06-2013, 07:26 PM
phil8825
I had the same problem, only in my cj the heater core pretty much blew up after I replaced the water pump, I had an ocean of coolant everywhere
Bypassed it for a a few weeks until I decided to replace it the other day
phil8825 is offline
post #7 of 13 Old 09-08-2013, 12:30 AM Thread Starter
LV2DRFT
Thanks for the help. I'll get to it!
LV2DRFT is offline
post #8 of 13 Old 09-08-2013, 07:21 PM Thread Starter
LV2DRFT
I read elsewhere that you can put 2-3 inches of brass or PVC pipe inbetween the in and out hoses after disconnecting them at the firewall, and clamp them back together. The PVC pipe's external diameter has to be the same as the heater hoses internal diameter.
All that makes sense, except I have one concern, I noticed that the two hoses are different thickness. What size pipe should I then get, or is there a special piece?
Thanks
LV2DRFT is offline
post #9 of 13 Old 09-08-2013, 07:34 PM
uberxj92
1992 XJ Cherokee
Get the one that fits the smaller hose. Then just use 2 hose clamps on the larger one. I've done this numerous times. There's not enough pressure to hurt it.
uberxj92 is offline
post #10 of 13 Old 09-08-2013, 09:28 PM Thread Starter
LV2DRFT
And sorry just one more question...
It's a 97 TJ 6 cylinder. I'm dealing with 11/16 and 5/8 I believe... I can clearly see the 11/16 on one hose, the other hose is hard to read but I think it says 5/8. I'd assume that means the interior diameter not the exterior diameter... in this case that would mean I'd be looking for a piece of 5/8 pipe. Someone wanna just confirm this for me please?
I can disconnect them to measure the ID with a ruler but then I'd have to drive it over to the hardware store after doing that. Just in case my bad luck kicks in and there's a problem after I take them out to measure, it would be good to get a confirmation on the size so I only have to mess with it once.
Thanks!
LV2DRFT is offline
post #11 of 13 Old 09-08-2013, 09:38 PM Thread Starter
LV2DRFT
This is what I was thinking about using...
http://www.homedepot.com/p/5-8-in-Le...1#.Ui00on_pwt0
Sound about right?
LV2DRFT is offline
post #12 of 13 Old 09-08-2013, 09:39 PM
uberxj92
1992 XJ Cherokee
When I do it I just take the hose in with me.
Good friend of mine tells me that they have bypass kits at part stores.
uberxj92 is offline
post #13 of 13 Old 09-08-2013, 11:25 PM Thread Starter
LV2DRFT
I stopped by Orielly first and picked up a heater hose coupler and 2 wormgear.
The coupler was 5/8" made by Doorman Help
Worked perfectly, and I doubled up on the 11/16 side with the new wormgear and the factory clip. No leaks and the hoses are hot for the first time in a long time.
Thanks for the help!
LV2DRFT is offline
