Leak from thermo housing - Help?! - JeepForum.com
post #1 of 4 Old 10-10-2001, 07:54 PM Thread Starter
EricsXJ
The Post man
EricsXJ's Avatar
Hey engine experts,
(background: 2000XJ, 4.0L I-6)
My Jeep has been parked in the driveway since last night. I opened the hood today and noticed a small amount of coolant leaking from what I think is the thermostat housing. I've suspected there might be a leak there from the crud buildup but this is the first time I've seen any fluid. It does not leak enough to drip on the ground and the coolant level is good.
Is this a serious problem that will progressively get worse? Should I take it to the dealer? (still under warranty) Or any other suggestions? Here's some photos so you can see what I'm referring to.
Eric
2000 XJ "PROJECT RUBICON" 3-link front / 4-link rear / coilovers / running 37's on Dana 60s
My website -
EricsXJ is offline
post #2 of 4 Old 10-10-2001, 08:50 PM
JeeperJay
If that is coolant I'd say that the thermostat housing gasket has sprung a small leak...is that gunk dripping from the thermostat housing or up from the water pump? Hard to tell by the pic. Doesn't look like a life or death situation but I'd still get it taken care of before it gets worse.
1992 YJ, 2.5L 4-banger, 2" Lift, 31x10.5 BFG Mud Terrain, K&N Filter, Restrictor Removed, Hi-Lift, Custom bumpers, More to come...
JeeperJay is offline
post #3 of 4 Old 10-10-2001, 10:35 PM Thread Starter
EricsXJ
The Post man
EricsXJ's Avatar
Yes its definitely coolant. You can't see it in the photo but the fluid is green in color. If it is just a leaky gasket, I suppose the dealer should be able to fix it without problem. I don't know if this is a common thing with jeeps or not.
Eric
My website -
EricsXJ is offline
post #4 of 4 Old 10-11-2001, 12:12 AM
Nightclaw
Dude, it doesn't matter if the thermostat housing is leaking or if you threw a rod through the engine block. Take advantage of that 36-month warranty your XJ came with!
'94 YJ Sahara Hardtop
4.0L / AX-15 / Stock NP231 / Stock D30 (open) / D60 (35-spline, Detroit locker, Moser axles) / rear disc brakes / 4.56 gears / Advanced Adapters SYE & CV Shaft / 33" BFG MT-KM's / Thorley Header / Magnaflow Muffler / BesTop Flares
Nightclaw is offline
dana 44 housing elkfan2 Engines & Drivetrain 19 12-18-2010 11:04 AM
Viking Thermo Rollers or Hawse fairlead for synthetic line? Kris B Krunch General Jeep & Off-Road Equipment 2 02-20-2008 05:02 PM
D30 LP axles in HP housing ? penguinland General Jeep & Off-Road Equipment 4 05-23-2005 05:53 PM
D35 is it the axle or the housing? Brett-n-GA General Jeep & Off-Road Equipment 14 05-18-2004 09:20 PM
I need a Bell Housing Jeepin Hillbilly Engines & Drivetrain 0 02-13-2002 07:57 PM
