Largest engine possible - JeepForum.com
post #1 of 9 Old 07-24-2005, 01:45 AM Thread Starter
Nate's Wrangler
hey this is nate again i was wondering what is the largest engine i could fit in a wrangler yj i have money to spend but keep it reasonable i want to spend no more than 6k
Nate's Wrangler is offline
post #2 of 9 Old 07-24-2005, 05:28 AM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
Mags have shown a V10 Viper engine in a TJ. A clubmate of mine has a 454 in a CJ.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #3 of 9 Old 07-24-2005, 08:42 AM
LT1CJ7
LT1CJ7's Avatar
1983 CJ7
811 ci should fit, but it's over your budget by $26,000 ........oh whell
[IMG][/IMG]
LT1CJ7 is offline
post #4 of 9 Old 07-24-2005, 10:11 AM
speedracer2536
put an lt1 in it cheap and esay
speedracer2536 is offline
post #5 of 9 Old 07-24-2005, 04:26 PM
LT1CJ7
LT1CJ7's Avatar
1983 CJ7
Hey, Why didn't I think of that
But I'll tell you..... Done correctly, It's not exactly cheap
LT1CJ7 is offline
post #6 of 9 Old 07-24-2005, 11:57 PM
Traveller
There's a shop down here that has an old Allison V12 airplane engine sitting in the back, a bit big for a Jeep, but I wonder if I could make it fit in a '69 El Dorado? The damn hood on the Caddy is like 8' long, of course the Caddy front wheel drive, hmmm.
Traveller is offline
post #7 of 9 Old 07-26-2005, 12:27 AM
TXjeepTJ
TXjeepTJ's Avatar
811 ci!!!! *drewling* that thing is beautiful........... LT1? LS1!!!
LS1 powered TJ
C6 Z06 Corvette
TXjeepTJ is offline
post #8 of 9 Old 07-28-2005, 02:41 AM
Brody
I like rainbows
have your pick jegs
its ez to get adapters for 302's and 350's
my pick ya so what if its a ford. its 450 hp!!! in a 302 block
add this for good mesure
then go upgrade your entire driveline because you cant run a 190 hp engine with out snaping an axle
Brody is offline
post #9 of 9 Old 07-28-2005, 03:40 PM
speedracer2536
lt1 is easy and cheap if you can get all the parts dirt cheap like paying 800 for a lt1
1500 for a nv4500 tranny 1000 for a dana 44 geared out of a waggy radiator for 350
and a atlas 2 for 1800 used plus all the misc can be done for 6k but not all the time
but i can be done
What's the largest tire I can put on my WJ chadburgwald Tires & Wheels 0 02-17-2007 03:06 PM
largest tire that will fit? Maximummud Tires & Wheels 4 07-09-2006 06:28 PM
Largest tires without lift Cranse Tires & Wheels 3 04-13-2006 05:53 AM
Largest tires that will fit are??? MPW400 Tires & Wheels 0 10-08-2003 02:49 AM
Largest Tire? LNDSRK Tires & Wheels 4 04-16-2002 02:24 PM
