-   Engines & Drivetrain (http://www.jeepforum.com/forum/f19/)
-   -   Knocking Underneath 2000 TJ (Automatic) (http://www.jeepforum.com/forum/f19/knocking-underneath-2000-tj-automatic-1561032/)
SJHeup 08-11-2013 08:18 PM
I've got 190K miles on my Jeep. No significant engine problems in the 10+ years I've had it.
But there is a knocking noise coming from underneath. It's not too loud when idle, but gets louder and accelerates as I accelerate. It still runs smooth and feel nothing out of the ordinary. I'm not very knowledgeable when it comes to "under the hood" stuff. The guy at NTB without looking at it said it sounds like a rod knock in the engine. So basically, he said it needs a new engine. My girlfriend's father who is a mechanic is looking at it next week and says it could be a rod, but it doesn't sound consistent with a rod knock and it has him somewhat stumped. Keeping my fingers crossed it's not the engine. Read a couple of things that said it could be something in the transmission. Just trying to research what it could possibly be when for when we get in there. Thanks for any help.
KLboxer 08-11-2013 09:34 PM
Could be your crank bearings are worn out. Anything in the lower end should be easily heard through the oil pan if you give a listen. Use the screwdriver trick* to isolate the location of the noise and that may narrow things down.
* The screwdriver trick is where you take a larger size screwdriver, hold the handle against your ear, and use the tip to probe around the engine compartment for the noise. It amplifies surprisingly well and can really help locate a problem noise. Just be careful and don't get your head, fingers, or the screwdriver mixed up in any of the moving parts.
SJHeup 08-11-2013 10:35 PM
Thanks! Doing the screwdriver trick is actually what got us thinking that it wasn't a bad rod. I just found a video of a Jeep running on bad crank bearings. Sounded pretty similar. No video of it accelerating though. Thanks!
uberxj92 08-12-2013 07:08 AM
Try draining your oil now and run s magnet thru the oil. See if you get a lot of metal. That would indicate bearings.
You could have piston slap too.
SJHeup 08-12-2013 07:33 AM
Ok. So 2 great replies (thank you KLboxer and uberxj92). So when first researching engine replacement, i was looking at a cost of roughly $3000-$5000. Does anyone know would it cost to replace those bearings? I know I'm going to spend a good amount on a 13 year old with almost 200K miles, but like i said before, just doing the research.
uberxj92 08-12-2013 07:52 AM
Titan engines in ocala Florida. Great strokers. My family shop Is a machine shop. We get $2000 for full rebuild. It depends on where you live the prices. But you can get the stroker motors for same price as most rebuilds and crates.
KLboxer 08-12-2013 04:48 PM
Pulling the oil is a good suggestion. You can go one step further and take the oil filter apart as well and see if there is any metal in there.
After re-reading your mileage, you may want to check into the condition of the timing chain/timing chain tensioner. Seems like that could be a likely cause given the high miles.
KLboxer 08-12-2013 04:51 PM
The bearing replacement would be cheap parts wise if you can get away with it. Labor is the killer when replacing major engine components.
hoaxci5 08-12-2013 05:23 PM
Flexplate? Mine was just replaced because of this...
SJHeup 08-12-2013 05:42 PM
http://www.youtube.com/watch?v=FUCrZ...JPP5PEpkt1Zkyg
Sounds very similar. Did the knock get faster as you accelerated?
hoaxci5 08-12-2013 06:44 PM
It did but it wasn't any where near as noticeable at speed.
uberxj92 08-14-2013 10:50 AM
Auto could be torque converter bolt loose.
Or the Prius you hit still has people in it lol
SJHeup 08-15-2013 08:07 AM
Thanks! And it was a Mini.
SJHeup 08-15-2013 08:12 PM
Hey guys and/or girls. I took a couple videos so you can hear what it sounds like.
Here it is from under the hood:
https://www.youtube.com/watch?v=oRbA...e_gdata_player
Here it is from underneath (mind the spider web)
https://www.youtube.com/watch?v=JK3T...e_gdata_player
Mercwerx 08-18-2013 10:52 PM
I'm going through the same thing, after taking off the pan there it was a broken piston skirt. It's a bit of work but not too bad
The time now is 01:19 AM.
