Knocking under driver side - JeepForum.com
post #1 of 3 Old 10-14-2012, 08:40 AM Thread Starter
bperks
I have a '99 Wrangler with 100k miles. Whenever I'm driving and go over a bump or slow down to a stop, there's this knock which seems to be underneath the drivers seat or center console. I was thinking maybe the transfer case linkage? Has anyone had this problem/know how to fix it?
bperks is offline
post #2 of 3 Old 10-14-2012, 10:04 AM
HAYSHAKER170
Sounds like the transfer case shifter linkage problem. There is a TSB number for this issue. There is a kit for $20 you can get from the dealer to replace the bushings. I did this but it only lasted about 2 yrs before it started knocking again. You may want to just put a Novak shifter in there and forget about it. Especially if you plan to do a bodylift or suspension lift in the future. I wish I had.
Update: I did a search and found this:
TSB 21-09-98 JUL 98
Transfer Case Shifter - Creaking/Thumping Noise
Part Numbers
05014148-AA Torque SH 21-105-001
HAYSHAKER170 is offline
post #3 of 3 Old 10-15-2012, 01:06 PM Thread Starter
bperks
Thanks man! Helped a lot.
bperks is offline
knock , problem , transfercase , wrangler
