-   Engines & Drivetrain (http://www.jeepforum.com/forum/f19/)
-   -   Knocking under driver side (http://www.jeepforum.com/forum/f19/knocking-under-driver-side-1427295/)
bperks 10-14-2012 08:40 AM
I have a '99 Wrangler with 100k miles. Whenever I'm driving and go over a bump or slow down to a stop, there's this knock which seems to be underneath the drivers seat or center console. I was thinking maybe the transfer case linkage? Has anyone had this problem/know how to fix it?
HAYSHAKER170 10-14-2012 10:04 AM
Sounds like the transfer case shifter linkage problem. There is a TSB number for this issue. There is a kit for $20 you can get from the dealer to replace the bushings. I did this but it only lasted about 2 yrs before it started knocking again. You may want to just put a Novak shifter in there and forget about it. Especially if you plan to do a bodylift or suspension lift in the future. I wish I had.
Update: I did a search and found this:
TSB 21-09-98 JUL 98
Transfer Case Shifter - Creaking/Thumping Noise
Part Numbers
05014148-AA Torque SH 21-105-001
bperks 10-15-2012 01:06 PM
Thanks man! Helped a lot.
The time now is 06:14 PM.
