jeep yj wont start - JeepForum.com
post #1 of 5 Old 09-18-2013, 07:22 PM Thread Starter
tommygunns72
jeep yj wont start
hey new to the site and best way to figure out my problem is asking you guru's. I have a 91 jeep yj 4l engine. my jeep turns over and its getting gas and spark from the coil to the cap but not from the cap to the spark plug. changed the coil, cap, rotor, wires, and plugs but still wont start. been reading a lot of posts about changing the cps and took one out of my 92 jeep and installed it. the distributor turns. I just put in a new clutch plate pressure plate and flywheel. can anyone help out thanks tom
tommygunns72 is offline
post #2 of 5 Old 09-18-2013, 09:08 PM
uberxj92
1992 XJ Cherokee
Does a stick have a neutral safety switch? Did you see if the can sensor in the distributor is good?
http://www.jeepforum.com/forum/f177/92-xj-sadness-2075657/index2.html
uberxj92 is offline
post #3 of 5 Old 09-18-2013, 10:08 PM Thread Starter
tommygunns72
no it doesn't have a safety switch don't know why haven't really checked the cam sensor yet. just hoping it might be something else before I buy a ohm meter to check what is the ohm suppose to run on the cam sensor?
post #4 of 5 Old 09-18-2013, 10:17 PM
uberxj92
1992 XJ Cherokee
Don't know maybe someone else does. Or Google may.
uberxj92 is offline
post #5 of 5 Old 09-19-2013, 10:07 PM Thread Starter
tommygunns72
ok changed out the old camshaft sensor or pickup coil and still no change!! at wits end now don't know what else it could be. keep thinking it mite be the flywheel I replaced when putting in new clutch plate
