Jeep will not start, super frustrating - Page 3 - JeepForum.com
post #31 of 48 Old 11-21-2013, 04:28 PM
uberxj92
1992 XJ Cherokee
On the small wire? Try changing the relay.
http://www.jeepforum.com/forum/f177/92-xj-sadness-2075657/index2.html
uberxj92 is offline
post #32 of 48 Old 11-21-2013, 04:30 PM Thread Starter
txrednek04
Very minimal to no volts on the small wire. Relay in PCM is good
txrednek04 is offline
post #33 of 48 Old 11-21-2013, 04:32 PM
uberxj92
1992 XJ Cherokee
No I would start looking into the ignition switch
uberxj92 is offline
post #34 of 48 Old 11-21-2013, 04:39 PM Thread Starter
txrednek04
Brand new
post #35 of 48 Old 11-21-2013, 04:40 PM Thread Starter
txrednek04
Brand new
And same with the ignition switch with the pin that tends to break
post #36 of 48 Old 11-21-2013, 04:41 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Before you do that check the fuses in your fuse panel...
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #37 of 48 Old 11-21-2013, 04:47 PM Thread Starter
txrednek04
I have gone through the fuse box. Fuses are good to go
post #38 of 48 Old 11-21-2013, 05:42 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
If you have voltage to the starter relay and the ignition send power to close that relay and send power to the starter solenoid wire and the big red wire has 12 volts with good amperage it should fire up.
If this starter is good; Turn the ignition key to the ON (not START) position. Put 12 volts to the small wire lug on the starter solenoid.
It should fire up....UNLESS you are missing a major ground point, or the starter relay in the PDC lost it's ground point.
Check the second ground from the firewall to the engine block.
post #39 of 48 Old 11-24-2013, 10:06 AM
zacko-zj
I forgot about something that is really obvious. Have you checked the neutral safety switch?
zacko-zj is offline
post #40 of 48 Old 11-24-2013, 10:12 AM Thread Starter
txrednek04
Yes I did and it did not work. Then I switched it out for the one off the old transfer case and still nothing. I ended up takin it to buddy of mine's shop so hopefully he can figure it out
post #41 of 48 Old 11-24-2013, 12:54 PM
doghouse8632
If u have a 12 volt test light... Attach 2 good ground. Next, have someone hold over ign switch 2 the crank position. Probe the starter housing, if the test light lights, u have a bad ground. Next take voltage drop tests of cables neg and pos. u need a volt meter 4 this test. 2 test the pos cable .. Hook 1 end of the meter to the pos post and the other end 2 the pos starter lug. Crank over the engine.. If u have over 2 volts or more. U have a bad connection or cable. Do the same 4 the ground cable..
doghouse8632 is offline
post #42 of 48 Old 11-27-2013, 11:18 AM
jpin86
On your first post you said your Jeep was a manual trans, so it wont have a neutral safety switch. Check the clutch pedal position switch, or google how to bypass the switch. I think there is a fuse to pull.
jpin86 is offline
post #43 of 48 Old 11-27-2013, 03:02 PM Thread Starter
txrednek04
I believe I also added that I know tht wasn't what it's actually called, but I couldn't remember what it was actually called. I did however check the clutch pedal position switch that's on the tcase and that is operational. As of now I took my jeep to my buddy's shop and he can't look at it till Saturday due to the holidays so I'll keep everybody posted on what it could be once he looks at it
post #44 of 48 Old 11-27-2013, 07:19 PM
jpin86
The clutch pedal position switch is located under the dash on the clutch master cylinder. There is a simple way to bypass the switch. Install a 10 amp fuse into a clutch bypass slot.
jpin86 is offline
post #45 of 48 Old 11-27-2013, 11:18 PM Thread Starter
txrednek04
That's slot 20 in the fuse box. Put one in there and I still had no luck with starting
