Jeep wanders a lot when in 4wd at speed - JeepForum.com
post #1 of 2 Old 12-26-2010, 12:19 PM Thread Starter
aciani7
Hey I was wondering if any of you guys might know why I am having this problem... I was on the highway the other day and it started to snow so I put my 2000 TJ (4" lift if it makes a difference) in 4wd. As soon as I put it back in gear it started to pull way to the right, so to correct it i just steered left. When I went to change gears, as soon as the front drive shaft wasnt being powered it shot way to the left because I had the wheel turned that way. This problem only seems to occur at higher speeds like 40+. I also just got an alignment about a week before that had happened and it runs good and straight in 2wd. Let me know if you guys have any ideas what this might be.
aciani7 is offline
post #2 of 2 Old 12-26-2010, 05:37 PM
mukluk
Most likely your front and rear axles aren't in line with each other, due to the misalignment your Jeep will pull to one side when power is applied and go the opposite direction when you pull the power off.
mukluk is offline
4wd , alignment , wander
Jeep YJ 5 speed won't go in gear? wolf654u Engines & Drivetrain 7 10-25-2010 08:02 PM
Jeep YJ , 2.5 , 4 cyl , 5 speed mogever Engines & Drivetrain 0 07-24-2009 02:09 PM
Top speed 88blaster Street Jeep Forum 39 04-28-2007 09:01 AM
Jeep Speed Secret Book alexrule123 Street Jeep Forum 18 02-13-2007 03:58 PM
3 speed or 4 speed for the trails? Tri_X_Troll General Jeep & Off-Road Equipment 12 01-25-2006 07:29 AM
