Jeep jk knocking sound 09' with tires and lift but no engine mod - JeepForum.com
post #1 of 11 Old 05-12-2012, 05:04 PM Thread Starter
sdaniels34
I posted a response to someone else on the forum about something similar. Our engines, however, are different and the technician at the dealership says the noise is coming from the transmission. There is a very noticeable knocking sound and a gear was blamed for the noise. The technician says the sound is normal. I only have 10000 miles left of my factory warranty. Should I push the dealership to deal with this differently? All of their tests show no trouble. I'm receiving notices in the mail from attorneys regarding my engine. Any advice?
sdaniels34 is offline
post #2 of 11 Old 05-12-2012, 07:39 PM
Griff1918
Take it for a 2nd opinion
Griff1918 is offline
post #3 of 11 Old 05-12-2012, 09:51 PM
Treton
when does it happen? when bogging down near stall?
Treton is offline
post #4 of 11 Old 05-13-2012, 06:58 AM Thread Starter
sdaniels34
It happens when during idol mostly when cold.
post #5 of 11 Old 05-13-2012, 08:05 AM
Griff1918
Sounds like a oil pump issue, or to heavy of an oil.
post #6 of 11 Old 05-14-2012, 03:52 PM Thread Starter
sdaniels34
Does oil pump/ oil weight impact the transmission?
post #7 of 11 Old 05-14-2012, 04:05 PM
Ross00TJ
No.
What oil grade (weight) are you running in your V6?
Try using a long scredriver, hose, etc as a stethoscope and probing around (by placing on end on various parts of the engine and the other part on your ear) to find where the noise is the loudest.
$20 says that the dealership techs didn't want to deal with it becasue it is warranty work.
Report back your findings (where the noise is coming from, specifcally) and we should be able to help you better. Otherwise try taking it to another shop for a 2nd opinion. I can't think of anytime when a knocking engine or tranny is normal.
HTH.
Future Electrical and Computer Engineer - University of Colorado - Boulder | Bringing Logic to JeepForum since 2010!
"Everybody is a genius. But if you judge a fish by its ability to climb a tree, it will live its whole life believing that it is stupid. Albert Einstein
Ross00TJ is offline
post #8 of 11 Old 05-15-2012, 12:16 AM Thread Starter
sdaniels34
Good advice. I appreciate it.
post #9 of 11 Old 07-29-2012, 10:18 AM
cfd308
I have the same "Issue" it sounds like its coming from the rear end somewhere, usually only in 1st and intermittent. Any help would be great appreciated!
cfd308 is offline
post #10 of 11 Old 02-11-2013, 01:59 PM
Ruggzyboags94
2005 WK
Forgot to give you my number and it says your inbox is to full. 7326873413
Ruggzyboags94 is offline
post #11 of 11 Old 04-09-2013, 07:02 PM
chevyboy67
2009 JK Wrangler
i have a similar issue with my 2009 jk 3.8 when at idle it is completly fine on start up the minute i try to put it in gear and start to taxi down the block it sounds like a piston or knocking sound only for about 2 minutes then gone but if i let it set for an hr starts all over again anyone have this condition with this pos 3.8 junk box
chevyboy67 is offline
