Jeep drivetrain swap - JeepForum.com
post #1 of 11 Old 11-04-2013, 11:53 PM Thread Starter
Mk50
I was wondering if I could buy a donor vehicle that runs good and just swap everything from it into my jeep. I'd swap engine axles transmission transfer case and all the computers and sensors. Would this work or is there more to it than that?
Mk50 is offline
post #2 of 11 Old 11-04-2013, 11:59 PM
SchizophrenicMC
2016 JK Wrangler
From one TJ to another, yeah, it's basically that simple. If, say, you wanted to swap a ZJ's V8 powertrain in, though, it'd be a bit more difficult. You'd need to create engine and transmission mounts for it, and possibly use different-length driveshafts.
But yeah, if you wanted to put the whole drivetrain of another TJ into yours, it'd be as simple as finding a donor with all the parts intact, and changing them over. Of course, the only real reason to do it that way is if the donor is cheap and has frame and body damage, or is otherwise unusable, but its mechanical bits are all in better condition than yours.
Signature rules are dumb
SchizophrenicMC is offline
post #3 of 11 Old 11-05-2013, 04:26 AM
uberxj92
1992 XJ Cherokee
Hi and welcome to the forums. Schizo is right.
May I ask why you want to swap everything ?
http://www.jeepforum.com/forum/f177/92-xj-sadness-2075657/index2.html
uberxj92 is offline
post #4 of 11 Old 11-05-2013, 09:10 PM Thread Starter
Mk50
I was thinking about doing it because I needed bigger axles and wanted more power and no ones ever mentioned doing a whole swap like this so I asked.
I'm thinking installing a Atk 4.7 baja stroker would be easier, it sounds like to install it you just swap everything from your old engine to the new one and replace what's worn out.
Mk50 is offline
post #5 of 11 Old 11-05-2013, 10:19 PM
uberxj92
1992 XJ Cherokee
Yep. I build strokers too. Easy as pie.
uberxj92 is offline
post #6 of 11 Old 11-06-2013, 02:33 PM Thread Starter
Mk50
Cool that's great uber
Do u have any tips or anything extra I need to get for a stroker swap
Mk50 is offline
post #7 of 11 Old 11-06-2013, 07:23 PM
uberxj92
1992 XJ Cherokee
They're straight bolt ins. I would use a 99 xj intake and tb with your sensors. Maybe a little better exhaust manifold too. Definitely use better injectors. The increase in displacement is rough on stock injectors.
Stock wires plugs and distributor are still just fine.
Just remember to break it in right before hammering it. Zinc additive for first 800-1000 miles then change the oil.
I guarantee you'll be way happier. You'll notice huge low end difference.
uberxj92 is offline
post #8 of 11 Old 11-06-2013, 09:51 PM Thread Starter
Mk50
What do you mean when u say tb with my sensors?
What injectors do you use? Part number?
Thank you for all your help
Mk50 is offline
post #9 of 11 Old 11-06-2013, 11:29 PM
uberxj92
1992 XJ Cherokee
Tb- throttle body. Use your jeeps sensors on it.
I don't have the part numbers any more. But I used Ford 5.0 24lbs/he injectors. Got em out of junk yard
uberxj92 is offline
post #10 of 11 Old 11-07-2013, 04:19 PM Thread Starter
Mk50
Okay thanks for the info
Mk50 is offline
post #11 of 11 Old 11-07-2013, 04:26 PM Thread Starter
Mk50
Have you had any problems from yours?
Mk50 is offline
axles , drivetrain , engine , swap , transfer case
