jeep a/c noise, quick temporary fix. - JeepForum.com
post #1 of 5 Old 11-19-2012, 10:36 AM Thread Starter
bezerk
Hi, I have a 94 4ltr. Auto, the a/c clutch has failed (making grinding noises too often) I can't take the car off road till after Xmas... If I disconnect the electrics from the pump, would it stop the grinding and still be safe?
Thanks in advance,
Bez
bezerk is offline
post #2 of 5 Old 11-19-2012, 11:12 AM
Millermagic
Thanks in advance,
Bez
If you pull the A/C relay in the fuse box, the clutch won't try to engage the compressor. If it's making noise without it trying to engage (IE the hvac system is off) ... then this wont' work.
2000 XJ - 3.5'' Lift & Skinny Mudders.
Previous: A CJ, Few TJs and JK.
Millermagic is offline
post #3 of 5 Old 11-19-2012, 11:47 AM Thread Starter
bezerk
Millermagic,
Thanks for that, will that not bypass the radiator fan as well?
bezerk is offline
post #4 of 5 Old 11-19-2012, 05:23 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
You can disconnect the connector at the Ac unit. If you can't reach that, then pull the connector at the pressure switch (which is usually easier anyway). It is on the right side of American Jeeps, however, your set up may be different. As stated above, if the grinding is constant, regardless of whether the clutch is engaged or not, then you have a bad bearing in the compressor. You will need to stop driving the rig till you can get it fixed.
jeepdaddy2000 is offline
post #5 of 5 Old 11-20-2012, 10:56 AM Thread Starter
bezerk
Thanks for that, I'll use that disconnection if the relay removal fails... But, I must say everything at the moment seems to be doing, or not doing as planned.
Thanks again.
bezerk is offline
