Jeep 4.7L low idle in drive stopped at light - JeepForum.com
post #1 of 1 Old 04-24-2012, 04:21 PM Thread Starter
shawnsbruno
Hello Jeepsters my 99 grand cherokee limited when at operating temperature stopped in drive the idle goes from 750rpm to 400rpm or lower like its going to stall. Tried this in reverse and the rpm stays at 750. Replaced fuel filter, AIC motor, cleaned throttle body, oem spark plugs. Put on snapon computer, misfire #6 so I replaced coil. No more misfires, still the same problem. Could not find no more bad readings. Maybe the TPC? Any suggestions!!! Thanks
shawnsbruno is offline
4.7 liter , rough idle , rpm , stalling at stop
part time light won't go off in 2 wheel drive Cardinell Engines & Drivetrain 0 12-16-2011 03:53 PM
jumping idle when in drive ... up down then Shut off rosco219 Engines & Drivetrain 0 12-14-2011 06:04 PM
rough idle in drive only? southernjeep80 Engines & Drivetrain 0 12-03-2011 09:18 PM
idle drops when put car in drive Apache100 Engines & Drivetrain 0 04-12-2011 02:45 AM
4.2 engine idle and when in drive/4 wheel intermittant engauging gadget Engines & Drivetrain 2 06-12-2002 07:35 AM
