Jeep 4.0 Roller Lifters - JeepForum.com
post #1 of 11 Old 08-16-2013, 12:02 AM Thread Starter
Trombly
Has anyone used/heard about those roller lifters from 505 Performance?
Was wondering if anyone had any luck with them, could give me some insight.
Thanks
Trombly is offline
post #2 of 11 Old 08-17-2013, 05:12 PM
Newtons3
Yes. I would not recommend them. There are 3 of us within about 5 miles of each other with lots of engine experience who have come to the same conclusion.
Newtons3 is offline
post #3 of 11 Old 08-17-2013, 07:47 PM Thread Starter
Trombly
Lol thats not what i wanted to read, is it because they fail a lot?
Trombly is offline
post #4 of 11 Old 08-17-2013, 08:01 PM
Newtons3
Partly. Partly because installation requires a HV oil pump indicating massive oil usage. Partly because the system has a built in useful life expectancy far shorter, in my opinion, than I feel we are paying for.
Newtons3 is offline
post #5 of 11 Old 08-17-2013, 08:42 PM Thread Starter
Trombly
Why would it need a HV pump, roller rockers require less oil. Have you used them on any jeeps?
Rock on! Thanks
Trombly is offline
post #6 of 11 Old 08-17-2013, 08:53 PM
Newtons3
Its not the rockers. Its the lifters. And yes, 3.
Newtons3 is offline
post #7 of 11 Old 08-18-2013, 11:44 AM Thread Starter
Trombly
I don't even know if this is real life right now lol, alright thanks dude ill just get a flat tappet.
Rock on!
Trombly is offline
post #8 of 11 Old 08-20-2013, 05:24 PM
super98lsc
x4. nitrided flat tappet, good high zinc oil and proper spring pressures and break in cycle.
06-Corvette z51-6spd,b&b,K&N low miles.
77-Corvette Stingray 496 BBC/TH400 built 667hp+
00 WJ 4x4, 4.7 stroker, turbocharged,..lots more..
01 WJ 4x2 4.7v8 Limited (needs valve job)
90 Grand Wagoneer 401 Edelbrock Heads, Lunati .510/.527 FT Cam, Edelbrock RPM Air Gap, Holley HP 750, Thorley Headers, HEI, Electric Fan w Digital controller,4" lift 31x10.50 Goodyear Duratrac's on Pro-Comp Wheels,new interior, seats,seals,Alpine and JL full system, Remote HEI, Clifford 2 way with remote start,windows,tailgate.
96 Cherokee Country 4dr/2x2 White/Tan 3" Lift Sahara 18" Wheels 32.5"'s 99up head and intake- for sale soon!
super98lsc is offline
post #9 of 11 Old 08-20-2013, 05:47 PM
baldfatdad
1984 CJ8
Anyone ever tried taping off the filter or pressure sender and running a line up to the valve cover? Raining oil down on the rollers that way.
baldfatdad is offline
post #10 of 11 Old 08-20-2013, 08:00 PM
super98lsc
Even Zack at 505 told me to run a solid flat tappet that they were having reliability issues with the roller lifters. This was about a year and a half ago. I went solid lifter, flat tappet and had it ground at lunati and nitrided it. one of the things I liked in the stock can was the lifter diameter, I used a comp on my first build with massive failure at 2200 miles. We know the spring tension was set too high by the head builder so not entirely a comp issue imho but prefer the larger footprint on the mopar unit. My 360 and 401 are also large diameter.
post #11 of 11 Old 08-20-2013, 10:38 PM
Newtons3
Why? That would make no sense. The oil through the pushrods is excessive lube for roller rockers. Yes, Ive run spray bars on both wet and dry sump Fords and Chevys, but only on endurance engines to cool the valve springs.
Newtons3 is offline
