jammed starter??? - JeepForum.com
post #1 of 7 Old 07-03-2012, 07:58 PM Thread Starter
supniceyeah
jammed starter???
since this is not for a Jeep, sorry if I'm in the wrong category and please move this if it is
anyways, my sister's boyfriend has a 91 mustang and doesn't know much about cars. he went to start it the other day and nothing would happen, no noise at all. he popped the clutch and gets a loud grinding noise but it does drive with reduced power and he was able to get it home
starting at the simplest solution first, I went over right before it got dark tonight and took a look, the starter (along with everything else) makes no noise at all when turning the key, so my theory, make fun of me if it makes no sense, is that the starter is stuck in an engaged position, causing it not to start, and causing the grinding noise when he does drive it. does that make any sense?
he's all bummed out thinking he blew his motor, but if that's the case wouldn't the starter try to engaged when turning the key though?
99 WJ,4.0, stock
93 ZJ,4.0, 5.5", 33x12.5 mts
96 ZJ,4.0, stock: deceased
87 YJ,4.2, stock: sold
supniceyeah is offline
post #2 of 7 Old 07-03-2012, 08:10 PM
LittleBluE
My Honda had a similar problem. The most common cause is the starter solenoid being stuck open causing the starter to always run. If you drive it like that you will burn the starter up. A well placed hammer blow fixed mine.
LittleBluE is offline
post #3 of 7 Old 07-03-2012, 08:19 PM Thread Starter
supniceyeah
turning the key does nothing though, and the starter makes no noise, any chance it could be burnt out and engaged? causing no start, no starter noise, and a grinding when driving after popping the clutch?
99 WJ,4.0, stock
post #4 of 7 Old 07-03-2012, 08:28 PM
LittleBluE
It may have been stuck open then the starter burned out and that's why your not getting anything when you turn the key? That's my guess
post #5 of 7 Old 07-03-2012, 08:31 PM Thread Starter
supniceyeah
that's what I'm thinking too, thanks for the help man! now if only it was on a Jeep so I could get to the damn thing, I got the bottom bolt off no problem, the top one I've tried everything. I felt like an idiot not being able to remove a starter haha
99 WJ,4.0, stock
post #6 of 7 Old 07-03-2012, 08:32 PM
LittleBluE
Hahahaha hey I couldn't get a milk jug off my front bumper so I had to drive around with one KB one off. It happens bro
post #7 of 7 Old 07-04-2012, 07:44 PM
dusterdude
Did you bother to check the solenoid
dusterdude is offline
Does a RAQ radio with jammed CD player have any value lsuber Audio, CB & Ham Radios, GPS, & Electrical 1 04-04-2012 05:36 AM
5.2l v8 starter the same as a 4.0? cj7man Engines & Drivetrain 3 03-30-2011 09:01 AM
Help!! New starter or something else? robibler Audio, CB & Ham Radios, GPS, & Electrical 1 08-20-2010 10:48 AM
2003 Liberty radio CD player jammed MtFactory Audio, CB & Ham Radios, GPS, & Electrical 0 09-21-2008 01:41 PM
Starter won't engage, how can I check the wires before replacing the starter Brendan Engines & Drivetrain 2 01-27-2002 10:35 PM
