Intake Manifold leak - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > Intake Manifold leak
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRuffStuff Memorial Day Sale!Rugged Ridge Modular XHD Snorkel Now for both 3.8L and 3.6
Unread 06-06-2005, 07:57 PM   #1
DWhitmore
This is a Holly Street Dominator Intake Manifold: Had to put a new thermo. housing on the intake because the old was corroded to nothing. Dried everything off, siliconed the gasket and put the new housing on. It started to leak right away, around the housing bolts and up through the bolts. Too tight maybe? Need help.
DWhitmore is offline   Reply With Quote
Unread 06-12-2005, 07:36 PM   #2
fuzz401
1978 CJ7
might want to look at hte holes for the bolt to make sure they dont go into the coolant
1978 cj-7 had since 1979
401 .030 over- full floating flat top pistons
crower solid cam 292 dur .500/.510 lift
turbo 400 tranny 2500 stall
model 20 transfer case
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
http://img2.photobucket.com/albums/v...slideshow=true
http://photobucket.com/albums/v31/fu...slideshow=true
13.461 @ 92.45 mph on 37" super swampers on 1/4 mile
fuzz401 is offline   Reply With Quote
