Intake/exhaust manifold - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > Intake/exhaust manifold
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineEngo winches available at www.rockridge4wd.com! Free shipp
Unread 03-06-2004, 10:44 AM   #1
bruins
I'm missing the stud/bolt for the manifold that is closet to the firewall. Not sure if it should be a bolt in there or a stud... does anyone know?? I've heard that maybe these engines came without that stud in place?? That doesn't sound right though. The motor is a 4.2l out of an '88 YJ.
thanks
bruins is offline   Reply With Quote
Unread 03-06-2004, 11:35 AM   #2
Dembones
I've been told there is a factory recall for that stud, you may want to call your local dealer and see what you can do.
Blue '94 Wrangler, 2.5L: Under monsterization
37" Claws/teralow/HPD44/Trussed HI9/5:38s/detroits/SOA, shackle reversal on rebuilt waggy and XJ springs.
Blue Jeep Club member 2
Much more info here
Dembones is offline   Reply With Quote
Unread 03-06-2004, 01:11 PM   #3
bruins
so it should be a stud... not a bolt that is located at the back of the engine... closest to the fire wall??
Unread 03-06-2004, 05:04 PM   #4
Dembones
It's a stud on mine, but it's a different engine from a different year. I'm pretty sure there's supposed to be one there though...
Much more info here
