Input Bearing Removal - AX-15 - JeepForum.com
post #1 of 6 Old 12-14-2008, 04:09 PM Thread Starter
2yjs4me
Can anyone tell me if there's a trick to getting the front input shaft bearing out. I removed the 2 clips in front and was hoping that it would slide out, but no go.. Any recommended tools/pullers??
thanks..
2yjs4me is offline
post #2 of 6 Old 12-15-2008, 01:44 PM
jdarg
I believe you have to separate the intermediate plate from the front casting and do it from the rear instead of the front.
'94 YJ - SBC/AX15/231, SOA, 8.8, 34" swampers
'06 LJ Rubicon - 31" ATs, OME 2.5", belly-up skid, other junk
'75 CJ5 - 232/T14/D20, 'glass tub w/ 2" BL, otherwise stock
jdarg is offline
post #3 of 6 Old 12-15-2008, 02:00 PM
JFM626
JFM626's Avatar
I have PM,d you.
JFM626 is offline
post #4 of 6 Old 12-04-2012, 08:16 PM
mcbee21
Did you have to break the tranny casings apart and remove the input shaft and bearing from the rear? I am having the same issue in my TJ right now and don't want to pay $1200 to have someone do it. Im just a normal DIY'er and have dropped my tranny before to fix some other things - any help would be great.
mcbee21 is offline
post #5 of 6 Old 12-06-2012, 01:13 AM
mmerlinn
If you want the best and most answers, always start your own thread. NEVER HIJACK SOMEONE ELSE'S THREAD.
mmerlinn is offline
post #6 of 6 Old 12-06-2012, 05:07 AM
mcbee21
Haha alright bud. Wasn't aware of tne etiquette
mcbee21 is offline
AX5 input bearing - allowable play and other ??? rebocardo Engines & Drivetrain 0 01-08-2008 04:03 PM
D44 bearing removal help Lostj Engines & Drivetrain 5 12-18-2007 11:48 AM
ax-5 input shaft bearing pharmacist25 Engines & Drivetrain 1 12-24-2006 12:02 PM
input shaft bearing replacement? Lavacrawler General Jeep & Off-Road Equipment 1 09-12-2003 10:13 PM
