Ingnition questions - JeepForum.com
post #1 of 2 Old 04-06-2013, 09:02 PM Thread Starter
adhdlacrosse16
2014 JK Wrangler
Ingnition questions
any one know if it is possible to have a I6 coil on plug ignition retrofitted onto a I6 that was originally had a distributor? i keep getting water under my dizzy and i am tired of having to wait for it to dry out
99' WJ... tank raise mesh grill homebrew cai
magnaflow 11226, banks header, bb sittin on 31s
adhdlacrosse16 is offline
post #2 of 2 Old 04-06-2013, 09:34 PM
GilaMtnJeep
GilaMtnJeep's Avatar
Do you know how the water is getting in? I ask because you may be able to seal it with a fine bead of silicone. Had the same issue with a sand rail I had years ago and that's how I solved it. Used a little non-hardening silicone and sealed the cap. Problem solved.
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
GilaMtnJeep is offline
