ignition trouble - JeepForum.com
post #1 of 1 Old 05-31-2012, 03:15 PM Thread Starter
sam4dpd
1972 CJ5
ignition trouble
HI, hope some one can give me an idea here. I have a 72 cj5 with 304 and motorola alt. I am using a painless harness and every thing has gone well until alt system because they don't provide tech on that.
Alt system puts out 14.4 at 850 rpm with 22 amps. once battery is charged up the coil over heats and spark stops. I can run, no prob, on battery but not with alt hooked up. The motorola system doesn't call for ballast and every thing I read on it says same. The grounds all test good, alt, coil, points and distributer all new and didnt run bad at all when it runs just off battery.
Hope some one has some Ideas
thanks
sam4dpd is offline
ignition hell, no key cylinder..need ignition wiring help Keepajeep Audio, CB & Ham Radios, GPS, & Electrical 0 01-12-2012 12:29 PM
Ignition trouble, won't turn over natesh Audio, CB & Ham Radios, GPS, & Electrical 7 07-28-2009 01:55 PM
help, having trouble w/ my 8.8 jipjip Engines & Drivetrain 8 02-21-2007 10:55 AM
still having trouble twotone Tires & Wheels 2 09-12-2004 11:04 AM
engine swap ignition trouble.... HELP! '79 CJ-7 Levi Engines & Drivetrain 1 06-28-2002 05:12 PM
