Ignition coil yj - JeepForum.com
post #1 of 9 Old 07-29-2013, 06:27 PM Thread Starter
1990yjoffroad
Ignition coil yj
My 1990 wrangler 4.2L 6 cyl is having a problem with the ignition coil. Even when the car is off there is still power to the ignition coil. and when I start the jeep it wont shut off. I just replace the ignition switch in it. The only way to stop the power to it is to disconnect the battery. Any ideas of what it is.
1990yjoffroad is offline
post #2 of 9 Old 07-29-2013, 07:42 PM
DaemonForce
Starter solenoid is stuck?
DaemonForce is offline
post #3 of 9 Old 07-29-2013, 08:01 PM
Siva283
Do the gauges and everyrhing stay on like the key is still one?
Its not the starter selinoid causing this.
Sent from my SPH-L300 using JeepForum
Ask me how I know...
Siva283 is offline
post #4 of 9 Old 07-30-2013, 01:46 AM
jnicewan
Check ASD relay in the relay box, try swapping it with another relay and see what happens.
jnicewan is offline
post #5 of 9 Old 07-30-2013, 08:11 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
It's carbureted. Also has that Motorcraft iginition box/module on it IIRC. Unplug it and see what happens.
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
post #6 of 9 Old 07-30-2013, 10:00 PM
jnicewan
Dang, I dont see how I missed that, maybe it was getting late. Anyway OP measure the power you have at the coil and see what it reads. The ign module and starter relay can both give power to the coil. The starter relay would supply 12v-battery voltage, the ign module pwr to coil goes through a resister wire and should be somewhere around 6 volts.
So at least you should get an idea of where the short is coming from due to the measured voltage at the coil.
jnicewan is offline
post #7 of 9 Old 07-30-2013, 10:10 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Also worth mentioning that those Ig Mods were notorious POSs and did really weird stuff.
post #8 of 9 Old 08-01-2013, 10:10 PM
jnicewan
Yea, I had some weird problems out of those in the past, on my CJ and a couple ford products. When I still had the 4.2 in my 83 CJ, even with all new parts (coil,cap,rotor,plugs,wires and module) for the ford duraspark crap, I swapped in a GM HEI distributor and it really improved the way it ran, idle, response, power was all better with the HEI.
jnicewan is offline
post #9 of 9 Old 08-01-2013, 10:34 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
You bet.
