Idle Problem - JeepForum.com
post #1 of 6 Old 09-16-2003, 09:04 PM Thread Starter
Trainer
Idle Problem
Need some help here...
I have an eratic idle problem, sometimes my Jeep will just decide to idle up to approx. 1500 or 1600 rpm. If I shut off the engine the idle drops back to normal, but if I dont it stays there...
No engine lights or anything abnormal.
Any suggestions???
Thanks
JP
'05 Rubicon
Trainer is offline
post #2 of 6 Old 09-17-2003, 05:20 AM
BamaJeeper
BamaJeeper's Avatar
Check the self diagnostic codes. Sounds like it could be AIS (Automatic Idle Speed) controller.
Out of the darkness comes light.
BamaJeeper is offline
post #3 of 6 Old 09-17-2003, 10:25 PM
RockPaws
RockPaws's Avatar
Yes check the codes. That can be caused by a air idle solonoid or throttle position sensor...usually.
01' Jeep TJ (Jeep #5)
3.5 RE Custom SuperFlex, Raingler, Kilby, Currie, Banks, Borla, American Racing, Custom mods, Always more in the works.
RockPaws is offline
post #4 of 6 Old 09-18-2003, 01:50 PM
LoOpY
the IAC usually doesnt fail, its usually one of the sensors that gives input to the ECM that controls the IAC. MAP, TPS, ECT are gonna be the main ones. A vacuum leak is also a slight possibility. However, like previously stated, my money is on TPS
LoOpY is offline
post #5 of 6 Old 09-19-2003, 05:25 PM Thread Starter
Trainer
Checked today, no codes...
how do I find out if its the TPS???
Thanks
JP
'05 Rubicon
Trainer is offline
post #6 of 6 Old 09-19-2003, 11:14 PM
BamaJeeper
BamaJeeper's Avatar
The common problem with the AIS is that carbon will build up on the cone and cone seat causing erratic idle problems.
Idle problem on my CJ7 ablack9134 Engines & Drivetrain 1 06-30-2009 02:12 PM
Idle Problem Datspoon Engines & Drivetrain 0 09-28-2008 07:35 PM
Weber 32/36 Idle Problem Culprit28 Engines & Drivetrain 2 01-05-2008 11:55 PM
Idle problem with new fuel injector... Silver87YJ Engines & Drivetrain 0 01-03-2008 07:37 PM
4.0L Oil Pressure Problem at Idle... buccaneerob Engines & Drivetrain 5 12-22-2004 10:25 PM
