I6 question - JeepForum.com
post #1 of 10 Old 03-31-2004, 08:25 AM Thread Starter
bamakrw
I6 question
OK, here's my question, ok the top of the valve cover, there are a couple of holes in it. One is the for the oil cap, and the other is for the pvc ??? and there is another hole in the rear that has nothing in it or over it. Is there supposed to be something in there? If so, what? Because there is nothing in mine.
bamakrw is offline
post #2 of 10 Old 03-31-2004, 08:29 AM
xxxflhrci
xxxflhrci's Avatar
A hose goes from the valve cover to a fitting on the side of the aircleaner. There should be a small filter mounted in the side of your aircleaner.
xxxflhrci is offline
post #3 of 10 Old 03-31-2004, 09:10 AM Thread Starter
bamakrw
That's not good. Wonder where I could find a pic of what it should look like? Wonder what would happen if I left it off?
bamakrw is offline
post #4 of 10 Old 04-01-2004, 07:25 PM
ZmOz
Both hoses are part of the CCV system. There is no PCV on a 4.0. The one on the front is larger and goes from the valve cover to the air box, the other one is smaller and goes into the intake manifold.
ZmOz is offline
post #5 of 10 Old 04-02-2004, 02:26 AM
xxxflhrci
xxxflhrci's Avatar
He doesn't have a 4.0. His Jeep is a '90 with the 4.2. So, he's got a PCV.
post #6 of 10 Old 04-02-2004, 02:29 AM
xxxflhrci
xxxflhrci's Avatar
You don't want to just leave it off, because there is vacuum there and you will suck dirt in to the engine. You also do not want to plug it up, because you will build pressure in the engine and develop an oil leak. You can get a plug in filter that goes in that hole. Lots of cars used to use them. Go to an auto parts store and get on the right size in diameter to fit the hole.
post #7 of 10 Old 04-02-2004, 07:27 AM Thread Starter
bamakrw
Maybe that explains why oil is always so filthy after 1000k miles???
I plugged that hole up with a cap. What kind of plug in fliter? I'm not sure that I know what your talking about and most of the guys in the auto parts stores do not either. At least around here they don't.
bamakrw is offline
post #8 of 10 Old 04-02-2004, 07:43 AM
xxxflhrci
xxxflhrci's Avatar
There are several ways to do it fix your problem.
1.) Unplug your hole, put a plastic elbow in the grommet, put a piece of hose on it, and then put one of the filters like goes in the side of the factory air cleaner on it. You will just have to zip tie it up. Your auto parts store should have these. I know Fram makes 'em. Or you could leave that filter off, and stop by a shop that sells Harley parts and get a mini chrome crankcase filter. They are about 10 bucks. You can just put it on the end of the hose with a clamp.
2.) You can leave the hole plugged and find a breather oil cap to fit.
Here's a link that shows the kind of stick in breather that I was talking about. It is part #K in the chrome dress-up kit. Of course, it is more bling than you need, but you should be able to get a regular one at most any good autoparts store, because lots of cars in the 60-70 range had 'em.
http://www.mm-inet.com/new/763867.htm\
Here's a great pic of what they look like.
http://www.jegs.com/cgi-bin/ncommerc...93&prmenbr=361
post #9 of 10 Old 04-02-2004, 07:52 AM Thread Starter
bamakrw
Hey Thanks!
I love this forum. It's kind of like having a bunch of mechanics right beside you that always have some good ideas. Thanks again.
bamakrw is offline
post #10 of 10 Old 04-12-2004, 08:34 AM Thread Starter
bamakrw
OK, I was going to work on my jeep this weekend, went out and noticed it was leaking oil pretty bad and I am assuming it is because that I had not unplugged that hole quick enough. So, now I have a leak along the sides of valve cover (that I just put a new gasket on). Am I going to have to go buy another gasket and re-seal it or will it some how quit leaking one I unplug the hole?
bamakrw is offline
Newbiee Question?? - grand cherokee thumping question geoff6194 Engines & Drivetrain 0 10-21-2009 11:13 PM
Width of rim question,,,,and **** Cepek rim question. UPSucks Tires & Wheels 3 09-15-2007 09:19 AM
OME vs BDS Question. And Gearing + Tire Question mferrari Tires & Wheels 6 01-15-2006 12:43 AM
Wiring question and meter question Highlander357 Audio, CB & Ham Radios, GPS, & Electrical 4 12-29-2005 01:20 AM
My 2" BB lift question - in depth, and HUGE question WheelinTJ2004 Tires & Wheels 11 02-01-2005 07:17 AM
