Jeep Enthusiast Forums banner
I4 to I6 Swap T Case Please Help!
679 views 1 reply 2 participants last post by  emcee5000
#1 ·
Almost done... have a 95 YJ I4 manual got I6 swap from 94 YJ manual can't figure out T Case Input shaft. Everything is done but this! Please help. Have AX-15 Tranny, used to have AX-5.
I have allready purchased Part #53006085 and #8350605 and neither of them will go in to T Case I have. The swap didn;t come with T Case but I thought they were the same. NP231 Help!
I can be reached at 804-334-6251.
Thanks in advance for any help! Gotta get this thing out of the shop allready!
Evan.
#2 ·
I did a 99 2.5 to 02 4.0 and went from an ax-5 to nv3550. From your post it appears you are already know you need to replace the 21 spline input to 23 spline input shaft. TJ's were easy they ONLY used the long input shaft. However, YJ's had numerous input shafts long/short depending on year. Call Advance Adaptors or Novack, they can lead you in the right direction.
Top
