I wanna get some bigger axles - JeepForum.com
post #1 of 12 Old 10-21-2011, 07:57 PM Thread Starter
lockerx2
1997 XJ Cherokee
I have Dana 30 front and Dana 35 rear on my xj....any suggestions on going with bigger axles? I want some strength
lockerx2 is offline
post #2 of 12 Old 10-21-2011, 08:01 PM
Technohead
Ford 8.8 or Dana 44 rear, alloy shafts in the front and you are good to go with up to 35's.
-Eric
Technohead is offline
post #3 of 12 Old 10-21-2011, 08:25 PM Thread Starter
lockerx2
1997 XJ Cherokee
All the same width?
lockerx2 is offline
post #4 of 12 Old 10-22-2011, 04:34 AM
Technohead
Close enough. The 8.8's from Explorers are just over an inch shorter.
Cherokees with tow package actually came with D44 rears for a couple years in the late 80's. If you find one of those it will bolt in perfectly.
-Eric
post #5 of 12 Old 10-22-2011, 09:40 PM Thread Starter
lockerx2
1997 XJ Cherokee
All right I think I will go with a explorer rear end...I'm gonna go with 4.88 gears
lockerx2 is offline
post #6 of 12 Old 10-23-2011, 07:33 PM
jeepn4life92
explorer rear is definitly a good idea, should drop right in with the leaf sprung suspensions of an xj, i actually just watched an episode of xtreme 4x4 on spike this morning where this was done
jeepn4life92 is offline
post #7 of 12 Old 10-24-2011, 06:26 PM Thread Starter
lockerx2
1997 XJ Cherokee
Was that episode the budget build on the camo xj?
lockerx2 is offline
post #8 of 12 Old 10-25-2011, 09:01 AM
jeepn4life92
yupp, sure was...if i remember correctly, that whole build was around 6500, and with that rear, you could do 35's and 37's are possible but its stretching it
post #9 of 12 Old 10-25-2011, 12:24 PM
mfalik
mfalik's Avatar
The Spike show "Trucks" also did a project called Cheap Cherokee, they installed a 8.8 as well.
MichiganTech Mechanical Engineer Alumni
1994 Wrangler Sahara - Jeep Project
2003 Dodge Ram 1500 (new truck)
2007 Mazda CX-7 (the new commuter car)
2005 Mitsubishi Lancer (Rear Ended - TOTALED)
1998 VW Beetle (SOLD)
1988 Jeep Cherokee Limited - (SOLD)
mfalik is offline
post #10 of 12 Old 10-25-2011, 05:23 PM Thread Starter
lockerx2
1997 XJ Cherokee
Yeah I didn't know arb air lockers were budgeting your build!
lockerx2 is offline
post #11 of 12 Old 10-26-2011, 10:59 AM
jeepn4life92
well i believe they were "budgeting" cause he welded the rear as part of his "original budget"...but then couldnt drive it on the street so it was now less expensive and more "budget oriented" to completely replace the entire rear axle and throw arb's in the mix cause it costed less than a trailer and a tow rig, lol, any selectable lockers are gonna be a little less budget oriented though, arb's just are more expensive than the rest
post #12 of 12 Old 10-26-2011, 11:38 AM Thread Starter
lockerx2
1997 XJ Cherokee
Haha true
lockerx2 is offline
