I think my syncros are off :( - JeepForum.com
post #1 of 7 Old 12-01-2004, 10:09 PM Thread Starter
Killer Angel
reading arround here, it seems like my syncros are out of line. It always gives the scraping sound going from 2nd to 3rd, and 3rd to 4th unless I like the RPM's go ALL the way down, then switch gears. It also scrapes downshifting from 5th to 4th, and 4th to 3rd. I am going to put some new 80w90 in there soon with some of the additive stuff, so hopefully that will help a bit.
How much is it to repair syncros that are off?
This is a 95 Wrangler 4banger btw.
95 Jeep YJ
Stock 4 banger
31" Scorpion A/T
Going to add:
3 1/2" Suspension Lift
1 or 2" Body Lift
Killer Angel is offline
post #2 of 7 Old 12-01-2004, 11:47 PM
Anthen27
They do not go off as you are saying, They wear out, Their (synchros) job to let you know is to get the next gear that you are switching to moving the same rpm as the present gear is spinning, But to let you know most are plastic or soft metal and they do wear out, Check your clutch for proper adjustment first, Is it hard getting into first gear?...............
Anthen27 is offline
post #3 of 7 Old 12-02-2004, 12:45 AM Thread Starter
Killer Angel
No, not hard at all.
95 Jeep YJ
Stock 4 banger
31" Scorpion A/T
Going to add:
1 or 2" Body Lift
post #4 of 7 Old 12-02-2004, 08:14 AM
fuzz401
1978 CJ7
does that tranny take 80-90 or auto tranny fluid a lot of the newer trannys take auto tranny fluid
1978 cj-7 had since 1979
401 .030 over- full floating flat top pistons
crower solid cam 292 dur .500/.510 lift
turbo 400 tranny 2500 stall
model 20 transfer case
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
13.461 @ 92.45 mph on 37" super swampers on 1/4 mile
fuzz401 is offline
post #5 of 7 Old 12-02-2004, 07:44 PM Thread Starter
Killer Angel
80w90, its the strait 4
95 Jeep YJ
Stock 4 banger
31" Scorpion A/T
Going to add:
1 or 2" Body Lift
post #6 of 7 Old 12-02-2004, 09:34 PM
ugrider21
i have a similar problem...grinds upshifting and downshifting into 2nd and upshifting into 3rd and 4th. its also hard to get it into 1st. could this be my syncro? its a 97 TJ 4.0
'97 Sport green, 4.0 5spd, Bestop supertop, RE 3.5", 33x10.5 BFG a/ts on 15x8 Cragar 397's, Warn rockcrawler front bumper, KC 100W on windshield, Hella 500 fogs on bumper, K&N intake, Flowmaster 40, Herc'd interior, B&M shortthrow, PORC SYE, Collis custom CV shaft, Nth Degree rear UCA's, Gopher-it bell-up, Novak t-case shifter, MORE 1" MML/BL.
ugrider21 is offline
post #7 of 7 Old 01-12-2005, 09:35 PM
97TJGUZZY
97TJGUZZY's Avatar
mine just started this, doesn't ever grind but sometimes i just can't get it into first gear...If i put it in reverse real quick it will let me go into first...this usually happens when i get off the interstate or after i have been driving around town...doesnt' happen all the time and doesnt' really happen when i first get in the jeep...only after driving for a while...Also, when it wont go into first it also wont go into any other gear except reverse...pressing the clutch in and out doesnt' help...I think im going to change my fluid and went and bought some "super tech" 80w-90 from wallmart but from the looks of reviews i think i may hold off on puttting that in adn buy some MT-90...by the way this is a 97 TJ 4.0...Anybody got any ideas? do i need to change my fluids or should i start looking at getting new syncros?
For info on outdoor adventures in South Carolina check out
97TJGUZZY is offline
