I need some advice....how hard is it to overhaul a transfer case? - JeepForum.com
post #1 of 3 Old 03-21-2006, 03:47 PM Thread Starter
rlacey
ok this my crazy idea. My transfer case makes funny noises. I brang it to the dealership and had a tech listen to it and he said that i probably have some shot bearings or something in the case but there is no way of telling without doing the work which would cost more then my jeep is worth. 4wd.com sells a overhaul rebuild kit that includes bearings, seals, shift pads and rtv seaant for $119.99. How hard of a project is this to take on? Ive never taken on such a project. Can anyone give me some advice? What kind of tools will I need to get by? Can I get the transfer case off the jeep in my driveay without a lift?
Ryan
1991 Jeep Wrangler Sahara
KC Daylighters
Hi-Lift Jack on the Hood
rlacey is offline
post #2 of 3 Old 03-23-2006, 08:29 AM
emcee5000
emcee5000's Avatar
Yes to all questions. You can easily remove the t-case in a driveway or garage in an 1 hour or 2 depending on stuck or broken bolts. Just make sure you use 2 people or a floor jack to drop it down, it's fairly heavy and awkward. Once out spliting the case is very simple. I have taken apart both ends of the case to replace the input shaft and did an SYE and I am by no means a mechanic. I would suggest getting an fsm for diagrams and proper torque specs. As far as tools a few sockets/wrench, few small screw drivers, BFH, torque wrench and some rtv.
emcee5000 is online now
post #3 of 3 Old 03-23-2006, 09:50 AM
-Jer-
http://www.4x4trailhunters.com/article.php?id=20
here's a well written article on rebuilding a 231. Might give you an idea what's involved.
-Jer- is offline
NP 231 transfer case. chain slapping case jetmech135 Engines & Drivetrain 1 01-01-2010 05:49 PM
Transfer Case mxz583 Engines & Drivetrain 1 08-29-2009 10:52 PM
how old is my transfer case? tuck Engines & Drivetrain 0 05-29-2009 11:46 PM
transfer case help Sundvl-88YJ Engines & Drivetrain 4 10-29-2006 01:59 AM
transfer case shift lever hard to shift phant0omx Engines & Drivetrain 1 08-18-2006 07:59 PM
