I need help with my peugeot ba10 5 transmission! - JeepForum.com
post #1 of 20 Old 06-28-2010, 08:46 PM Thread Starter
fishjunkee1313
Recently my peugeot ba10 5 on my 1989 jeep yj went out. In abotu 6 months I am going to replace it with an nv3550 but I need a solution now so I am rebuilding it. After getting the gear box seperated from the rest of the set up, I cannot get the case split open. On the front end of the transmission there is a plate that connects the bellhousing to the rest of the transmission. to split the case I assume I must remove this plate but i cannot get it off. I assume it has to do with the bolts that hold the bell housing on but because they use nuts to keep tight I do not know how to remove them. Does anyone know how to do this?
fishjunkee1313 is offline
post #2 of 20 Old 06-30-2010, 08:44 PM Thread Starter
fishjunkee1313
no more problems with it
post #3 of 20 Old 06-30-2010, 08:45 PM Thread Starter
fishjunkee1313
i found a stud extractor and that did the trick
post #4 of 20 Old 06-30-2010, 08:46 PM Thread Starter
fishjunkee1313
now i have to find the problem
post #5 of 20 Old 06-30-2010, 08:46 PM Thread Starter
fishjunkee1313
all synchros look good
post #6 of 20 Old 06-30-2010, 08:47 PM Thread Starter
fishjunkee1313
all linkages werer fine
post #7 of 20 Old 06-30-2010, 08:48 PM Thread Starter
fishjunkee1313
all gears look like new and no metal shavings
post #8 of 20 Old 06-30-2010, 08:49 PM Thread Starter
fishjunkee1313
when i went to remove the drain plugs, i could not find the right size tool. it is a metric square head, 8 mm i think. i enmded up grinding down and old 3/8 extension. anyone know where to find one
post #9 of 20 Old 06-30-2010, 08:50 PM Thread Starter
fishjunkee1313
tranny works in all gears except reverse, and when in neutral it stalls as if it werer in second
post #10 of 20 Old 06-30-2010, 08:51 PM Thread Starter
fishjunkee1313
in reverse it stalls but doesent jerk either way, as if the tranny is just stuck
post #11 of 20 Old 06-30-2010, 08:52 PM Thread Starter
fishjunkee1313
found a busted shift fork inside
post #12 of 20 Old 06-30-2010, 08:53 PM Thread Starter
fishjunkee1313
how do i install shif lever retainer rings
post #13 of 20 Old 06-30-2010, 08:58 PM Thread Starter
fishjunkee1313
drualast slave, fell apart after two days
post #14 of 20 Old 06-30-2010, 08:59 PM Thread Starter
fishjunkee1313
buy the high end slave for this clutch!
post #15 of 20 Old 06-30-2010, 08:59 PM Thread Starter
fishjunkee1313
shift lever wont go back in
manual transmission , transmission case
name of driver tool for BA10 sugfree Engines & Drivetrain 0 12-31-2009 12:10 PM
name that BA10 tool please sugfree Tires & Wheels 0 12-31-2009 12:00 PM
BA10/5 stuck in 1st gear mountaineerX Engines & Drivetrain 0 01-27-2009 03:38 PM
new to site and need help with peugeot tranny rmelvin23 Engines & Drivetrain 1 08-31-2008 05:02 PM
peugeot trans my litte red yj Engines & Drivetrain 3 06-23-2002 08:08 PM
