I need help with my CJ5 - JeepForum.com
post #1 of 18 Old 07-22-2013, 08:24 AM Thread Starter
pearlriver09
I'm new to the jeep world. My cj needs a transmission and transfer case but I do not know which one. I do not know much about jeeps i i know mine has a 304 amc though. so I was hoping someone on here could help me out.
Sent from AutoGuide.com Free App
pearlriver09 is offline
post #2 of 18 Old 07-22-2013, 08:26 AM Thread Starter
pearlriver09
The transmission that's in it is a 4 speed
post #3 of 18 Old 07-23-2013, 06:17 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Do you have a year?
Have you googled the year and checked to see if the picture matches what you have in there? Stock 4 speed transmissions would be T98/18, T176, and SR4.
If you don't have one of these, then post a pict of it so we can have a look.
jeepdaddy2000 is offline
post #4 of 18 Old 07-23-2013, 09:31 PM Thread Starter
pearlriver09
Yes sir sorry its a 1980 i have looked at the picture and looked at it looks like the t176
post #5 of 18 Old 07-23-2013, 09:33 PM Thread Starter
pearlriver09
C300-15-2 this number is stamped into the transfer case I'm assuming its a d-300?
post #6 of 18 Old 07-23-2013, 10:46 PM
TMLoftis
1978 CJ5
Yes the 300 came behind the t176.
TMLoftis is offline
post #7 of 18 Old 07-24-2013, 06:23 AM Thread Starter
pearlriver09
What transmission and what transfer cases is it? What is there condition?
post #8 of 18 Old 07-24-2013, 06:25 AM Thread Starter
pearlriver09
That was suppose to go in a different thread sorry. Okay thank you very much it's stressing me out trying to find one is there any other ones that will go in it I found a guy with a t150 d20 combo relatively close to me would that work?
post #9 of 18 Old 07-24-2013, 05:33 PM
jeepdaddy2000
1971 CJ5
While the 150 is a good transmission, I would consider it a downgrade. What are you trying to do? Is the transmission bad? They are rebuildable and the 176/300 combo is a great pairing.
post #10 of 18 Old 07-24-2013, 10:29 PM Thread Starter
pearlriver09
Yes I believe it is bad it won't move at all in 1,2,3,r just makes terrible grinding sound. In 4 it acts like it wants to move but still has a grinding sound
post #11 of 18 Old 07-24-2013, 10:30 PM Thread Starter
pearlriver09
I'm trying to fix the jeep for as little money as possible as I'm on a budget trying to buy a house. All my friends are going riding and I can't go without my jeep
post #12 of 18 Old 07-25-2013, 06:06 AM
jeepdaddy2000
1971 CJ5
Do yourself a favor and take a deep breath....
Do a bit of troubleshooting. Is it the transmission? Clutch plate break? Transfer case? Rear axle? Bad driveline slip yoke?
Get a friend to put it in gear while you check the drive lines. Are they spinning? Will it move in four wheel drive?
Drop the t case inspection plate and check to see if there is an issue in there.
If it is the trans, pop the lid and take a look inside. It is rare to loose all the gears.
post #13 of 18 Old 07-25-2013, 10:20 AM Thread Starter
pearlriver09
Yes sir I'm going to do that in about a hour I appreciate you help ill post back with a conclusion
post #14 of 18 Old 07-25-2013, 09:30 PM Thread Starter
pearlriver09
Okay trouble shot it there a gear in the very front of the transmission missing all kind of teeth and is rounded off and the bearings are shot. I bought a t150 with d20 I was told that this will go right in with exception of drive and maybe bell housing ?
post #15 of 18 Old 07-25-2013, 11:24 PM
Chewtoy
1976 CJ5
you will have to reset the front and rear drivelines as the T150/D20 is shorter than your current setup. By the time you spend the money to rebuild drivelines and other little things to fit the new set you could have rebuilt the T176. Not to mention the set you have now has a better low range than the T150/D20...
With a great Jeep comes an empty wallet.
Chewtoy is offline
