-   Engines & Drivetrain (http://www.jeepforum.com/forum/f19/)
-   -   I need help!! (http://www.jeepforum.com/forum/f19/i-need-help-1327690/)
sakicnut 02-11-2012 09:28 PM
What is causing this weird noise?
Ok so i have a 1997 Wrangler TJ, so these last two night's it's been around in the mid teen's here in TN. So today on the way to work, i get ready to and pull out of our driveway; so i go to let off the clutch and the jeep rolls forward then just tries to stop on me.... So after work i get ready to back out and it starts going backwards but then i just stop's (almost like someone threw a block of wood behind the tires), so then i go to do it again and something in the rear right end pops fairly loudly.... So i go to pick my brother up and i turn into my grandparents driveway and the rear backend starts shaking(almost like i had a flat tire)..... What could be causing this?
boondaba 02-12-2012 05:49 AM
Sounds like somethings let go in your differential. :eek:
Pull your dif cover and check for any pieces of steel that may drain out of the oil.
If nothing, grab a flashlight and start inspecting your carrier and gears. If its acting up as bad as you say, something should pop right out at you.
sakicnut 02-13-2012 09:14 PM
It was actually where I didn't let the gears in it warm up enough during these cold nights.... So glad it wasn't anything major :)
herbiehind 02-14-2012 10:50 AM
brake hanging up.
The time now is 07:53 AM.
