I cant find my front differential - JeepForum.com
post #1 of 7 Old 02-01-2016, 11:06 PM Thread Starter
Kjminson
I have a 98 jeep grand cherokee i bought a couple thousand miles ago
I went to go check out my front diff(which i thought whay supposed to
Be in the front axel) and i cant find it for the life of me. Do some
98 jeep grand cherokees 4.0 v6 2wheel drive jeeps not front diff?
Kjminson is offline
post #2 of 7 Old 02-02-2016, 09:19 AM
biffgnar
biffgnar's Avatar
No reason for a 2WD vehicle to have a front diff
Romney in 2020!
biffgnar is offline
post #3 of 7 Old 02-02-2016, 10:09 AM
MurdaJs
2wd front axle
4wd axle
MurdaJs is offline
post #4 of 7 Old 02-02-2016, 09:50 PM Thread Starter
Kjminson
Thanks guys, i changed my rear diff fluid it was whinning alot, not its whinning and almost sound like its grinding, i used 75 90 i think, shouls i got with 140? Or is the any additive to quite it down
Kjminson is offline
post #5 of 7 Old 02-02-2016, 10:20 PM
jnicewan
No, the noise will not go away with a different fluid or additive. You have a problem more than likely with a bearing or possibly gears. Without knowing more info or hearing it in person you are going to have to take steps to eliminate/find the culprit. I'm talking about bearings in the rear axle ( axle/wheel bearings, differential side bearings, pinion bearings, then possibly a problems with the spider gears or ring/pinion gears.
jnicewan is offline
post #6 of 7 Old 02-02-2016, 10:38 PM
ravenworks
ravenworks's Avatar
Put some Sawdust in it.
Semper-Fi "81-84"
I.U.O.E. - 18
ravenworks is offline
post #7 of 7 Old 02-03-2016, 01:38 AM
RandyGPr
2nd time I heard that in two days.
RandyGPr is offline
