Hypereutectic -vs- Cast Pistons - JeepForum.com
post #1 of 3 Old 04-14-2004, 06:52 PM Thread Starter
karter74
Hey guys, I need some help on deciding what pistons to use on my rebuild of my 87 XJ. I don't plan on stroking it due to my inability to find a 4.2 crank and rods (if you know where I can find some, please tell me!) so I want to go ahead and just do a small build up of the 4.0. Right now my current plans are getting either the Sealed Power 677P or the Hypereutectic pistons of the same. I will be boring the engine .030" over and putting in either Crane Cams 753901 or 750501 (can't decide, since I'm not stroking the engine, what cam is good for me?) I hear good/bad things of the Hypereutectic pistons, saying they are stronger, yet more brittle to higher performance. Which should I use to rebuild the engine, Hypereutectic or the normal cast? Thanks!
karter74 is offline
post #2 of 3 Old 04-15-2004, 10:49 AM
MudMonster
MudMonster's Avatar
PM Mudlover to ask about the crank
"Don't be too proud of this technological terror you've constructed"
RED JEEP CLUB MEMBER #78
BIG GUNS AND JEEP OWNERS OF AMERICA CLUB MEMBER #3
Red Neck Jeep ClubMember#27Fire Engine Red '85 CJ-7, Howell FI-258, T-176, D300, 9", Warn Internal Hubs, Wagoneer front springs, RE Wrangler's in the rear, 33" TrXus', HEI conversion, Taurus fan, no emissions junk, and some 150w daylighters
MudMonster is offline
post #3 of 3 Old 04-16-2004, 08:34 AM
KAKERS
The Hypereutectic are a good choice for moderate, naturally aspirated performance applications. They are generally considered a compromise between the strength of a forged, and the thermal stability & lightness of a cast piston. For a run-of-the-mill 4.0, whether stroked or not, they are overkill. Go with the cast, you won't be disappointed. Should be cheaper too.
For the 4.2 crank/rods try Hesco in Birmingham AL. They sell 4.0 stroker kits and will definitely have access to the crank/rods/pistons you're looking for. Good luck.
KAKERS is offline
help with pistons stormkaster Engines & Drivetrain 24 02-20-2010 11:49 AM
Highlift Jack cast/steel or all cast JEEP97TJ General Jeep & Off-Road Equipment 3 07-17-2007 07:16 PM
Which Hi Lift? All cast or cast/stamped. Flyingbrass General Jeep & Off-Road Equipment 10 03-03-2005 01:32 AM
Pistons for 360 Mackddy6 Engines & Drivetrain 2 12-07-2001 09:28 PM
Pistons Mackddy6 Engines & Drivetrain 0 10-23-2001 09:52 AM
