Hydraulic clutch system troubles - JeepForum.com
post #1 of 4 Old 09-02-2013, 09:57 PM Thread Starter
skool_u
Hey all,
Just started having issues on my '92 YJ. It's the clutch system, specifically the hydraulic system it seems. I first noticed that the clutch wasn't very springy upon release and it would be difficult coming back all the way up but occasionally it would resort back to normal. I went for dinner today and the clutch pedal was all the way down to the floor with virtually no pressure. I thought I'd have to have it towed. I pumped what little it of travel I had on the clutch and it's almost as if it came back to life and I was ale to make it home; however, it still feels as if it'll give out again.
Upon checking the clutch reservoir, that little boot I side was a bit twisted and contorted. It was all squished to one side and did not look to be seated properly. To be honest it does not even look like it should be fitting in there because it's pretty big. Either way , it came out of there and there was still fluid in the reservoir.
My question is , would this be the culprit to my clutch issues or is there something else that cold be causing it? I don't seem to be seeing any major leaks on the ground but I might have missed something. Any insight would be appreciated. Cheers!
skool_u is offline
post #2 of 4 Old 09-02-2013, 10:19 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
We're you leaking any fluid? Was there any missing?
Luck Favours The Prepared
Anticanman is offline
post #3 of 4 Old 09-02-2013, 11:23 PM Thread Starter
skool_u
Seems to be about half full so don't think I'm missing much. It also seems to be intermittent and it seems that I tore that diaphragm thing because I placed it in incorrectly and the threads ripped it.
That being said, not sure if it was messed up because there was no way it was fitting in properly! It just kept sliding around and not lining up.
skool_u is offline
post #4 of 4 Old 09-03-2013, 12:54 PM
schitzangiggles
King of Macastan
schitzangiggles's Avatar
Get a new master cylinder. Mine did exactly the same thing yours did right before it failed and tried to take out the car in front of me at a stop light. IIRC it was @ $39 at Oreilly's.
I6/I4 looks to be the same part #
http://www.oreillyauto.com/site/c/se...ler&vi=1185083
If you could fill out your profile it would help us help you.
"Axeheads are supposed to be sharp, but you are one blunt tool."
FLynes
If you love wealth more than liberty,the tranquility of servitude more than the animating contest of freedom, go home from us in peace. We seek not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains sit lightly on your shoulders and may posterity forget that you were our countrymen.
-Samual Adams
A government big enough to give you everything you want is big enough to take everything you have.
Thomas Jefferson
Calling Illegal Aliens "Undocumented Immigrants" is like calling drug dealers "Unlicensed Pharmacists"
Nemo Me Impune Lacessit
"No one provokes (attacks) me with impunity".
"Your right, the Tea Party and the OWS are the same, just like the America Revolution and the French Revolution were the same. The only problem is the American Revolution ended with Liberty, Freedom, Justice for all and a shining light upon a hill. The French Revolution ended with lynchings, guillotines, murder and socialism. So yeah, I could see how one could confuse the two..."
Mac Wilson
schitzangiggles is offline
