Hydraulic clutch problems - JeepForum.com
post #1 of 2 Old 10-17-2010, 02:57 PM Thread Starter
the_fuzz
1993 XJ Cherokee
1993 jeep Cherokee, 4.0 H.O, 5-speed Aisin-Warner AX15. One day I started my Cherokee and I had it in first gear with the clutch petal pressed and it began to lurch forward and I couldn't pull it out of gear to I had to shut it down. After that i replaced the master cylinder and i didn't happen for a while. Well today the same thing happened to me. After I shut it down, it seemed to run perfectly fine. the new master cylinder doesn't have more than 3000 miles on it. What could be causing this problem?
the_fuzz is offline
post #2 of 2 Old 10-18-2010, 06:47 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
The slave cylinder is going bad...........
cruiser54 is online now
5 speed , ax15 , clutch master cylinder
Clutch problems Chance1229 Engines & Drivetrain 2 07-06-2010 02:17 PM
Hydraulic to manual clutch linkage swap? YJake Engines & Drivetrain 0 02-13-2009 02:50 PM
New clutch problems Commando360 Engines & Drivetrain 1 07-28-2008 11:15 AM
Any ideas how to convert manual clutch linkage to hydraulic with slave cylinder? jphillips13 Fabrication Shop 2 07-09-2008 05:15 PM
Clutch Problems qjones05 Engines & Drivetrain 5 10-01-2007 11:18 PM
