Humvee drop axles? - JeepForum.com
post #1 of 6 Old 06-24-2013, 07:47 AM Thread Starter
jeepmutiny
1983 CJ7
Humvee drop axles?
Anyone ever install Humvee military axles in a Jeep? I have never really messed with them and was wondering about swap issues and strength. Thanks Jon
jeepmutiny is offline
post #2 of 6 Old 06-24-2013, 08:26 AM
chriskeenan
the HMMWV is IFS/IRS with portal ends IIRC, it'd be easier to swap in unimog axles if you're after the portals.
chriskeenan is offline
post #3 of 6 Old 06-24-2013, 08:43 AM Thread Starter
jeepmutiny
1983 CJ7
Wasn't sure how they work other than being independent A frame. I have looked over a couple Unimog trucks at the military collectors shows I go to but I would think parts would be scarce in the U.S.A.....Jon
post #4 of 6 Old 06-24-2013, 08:47 AM
mike_breaker_5
hmmwv axles are crazy wide for a wrangler, mog sticks would be better. they are an independent suspension portal design.
i saw a guy on pirate put IRS axles in his rig. i think they were aluminum corvette dana 60's or something crazy like that. very cool, but WAY more work than i would want to do.
dynatrack makes portals that are bolt on for tj/jk if your pockets are deep enough.
Ratmonkey donation page. all proceeds will go to his family.
it's not much to look at... but it's mine.
5.2lswap, metalcloaks, bedliner, tucked belly, d60's, soon to be nv4500 and d300.
mike_breaker_5 is offline
post #5 of 6 Old 06-24-2013, 02:53 PM
jason m
Nothing but the facts
jason m's Avatar
404 U mogg axles would be better choice, but as with any portal design I like them a lot but one thing I don't like is when you rollover you take a big risk of breaking the portal box.
The leverage when the tire strikes the ground is not in a center line with axle, so it will always want to force the box inward when contact happens, so this will normally crack the portal box.
A few ways to combat this is get larger portals like 416 axles, or after market steel boxes, but once that's done at what cost are a set of well built 60/14 bolt that will offer you the same strength and no chance of portal box breaking.
Plus the other down side is making the pinion match and dumping the torque tube design..
You can plug the Humvee portal boxes onto a set of 9" axles, but oiling becomes a slight concern at higher speeds as you need the pinion flipped to make it go forward. Crawling no big deal, short burst your fine, a lot of highway driving I cant see the pinion lasting long.
Jason.
1993 YJ 4.0 60 Front, Rear steer 60, bolth spooled, 5.38's, 700r/241 39.5 iroks and beating it like it owes me money.
And on the 8th day, God created the 14 bolt...
The happiest people don't have the best of everything, they make the best of everything.
jason m is offline
post #6 of 6 Old 06-25-2013, 04:53 PM Thread Starter
jeepmutiny
1983 CJ7
So much for that idea, I saw online they make a 5 ton version that is stronger by spec than a Rockwell but same issue of a 7:00 something gear. You would have to run a 50 inch Terra to get above 55 MPH. I do like the extra clearance but not at the cost of hauling it everywhere. No fun if you can't drive it Ya know. Just reviewing all options and it seems a Gm or Dana 60-70 would be the best option for realistic gearing and drivability. But I guess that is why you can get a Unimog rebuilt axle for 1200 and a high pinion 60 costs 5-7 grand from Currie.....Jon
