Hp30 - Page 3 - JeepForum.com
post #31 of 50 Old 10-22-2012, 08:36 AM Thread Starter
goldeagle06
Alright thanks. Any recommendations on paint?
goldeagle06 is offline
post #32 of 50 Old 10-22-2012, 08:39 AM
Jason
What ever the cheapest spray paint you can find. It's an axle, so it's going to get scratched up. Spray paint is easy to touch up.
Jason is offline
post #33 of 50 Old 10-22-2012, 09:33 AM Thread Starter
goldeagle06
True
post #34 of 50 Old 10-23-2012, 10:45 AM Thread Starter
goldeagle06
I ended up using a pitman arm puller to push out the sway bar bolts worked great
post #35 of 50 Old 10-23-2012, 10:50 AM
Jason
Cool
Jason is offline
post #36 of 50 Old 10-25-2012, 09:30 AM Thread Starter
goldeagle06
Anyone use alloy ujoints? Or should I just put oem in my shafts?
post #37 of 50 Old 10-25-2012, 09:37 AM
FKemp3
Everything from the knuckle out will depend on what year the HP30 is. I dont remember the years, but some of the HP30's had the smaller brakes and you can swap the knuckles to obtain the larger brakes.
FKemp3 is offline
post #38 of 50 Old 10-25-2012, 09:51 AM
Jason
I just used the Spicers.
Jason is offline
post #39 of 50 Old 10-25-2012, 04:57 PM Thread Starter
goldeagle06
5-297X or 5-760X which axles do I have? I have the big ones
post #40 of 50 Old 10-25-2012, 06:20 PM
FKemp3
760, and SHOULD be the larger brakes and be a newer axle model
FKemp3 is offline
post #41 of 50 Old 10-25-2012, 08:41 PM Thread Starter
goldeagle06
I'm just gonna swap the knuckles and everything off of my 06 lp30
post #42 of 50 Old 10-25-2012, 09:14 PM Thread Starter
goldeagle06
My tcase is binding when I turn and I know the one axle ujoint is bad. Could that bad ujoint be what's causing the tcase to bind when I turn?
post #43 of 50 Old 10-25-2012, 10:56 PM
Jason
Is this occurring in 4wd? Why do you think the t-case is binding?
Jason is offline
post #44 of 50 Old 10-26-2012, 06:16 AM Thread Starter
goldeagle06
It does it in 4 or 2 and I put the front up on jacks and unbolted my rear driveshaft and put in in 4 wheel and gear and turned it left and right and when I turn the wheel my tcase starts clunking
post #45 of 50 Old 10-26-2012, 07:55 AM
Jason
To clarify; in two wheel drive, you hear clunking that you believe is in the transfercase, but only when you turn the steering wheel while under power?
Jason is offline
